DVD+RW på spindel fra Clas Ohlson
Er det noen som har testet disse 4xspeed +rw platene som er levert i 25-pakning? Kjøpe en pakke, og testa en på min Benq-brenner, men etter den ene plata ville ikke brenneren mer :wallbash: Koden innerst på plate sier : PWD656IE0610545038. Er dette bare møkkaplater? Er det bare å hive de resterende 24 platene?
Har endelig fått meg ny brenner. sjekka platene med 'dvd identifier' , og fikk denne infoen:
** INFO : Drive = BENQ DVD DD DW1620 [FW B7T9]
** INFO : Write Capabilities = DVD+RW DVD+R DVD+R-DL
** INFO : Write Capabilities = DVD-RW DVD-R
** INFO : Disc = [DVD+RW:PHILIPS-041-000]
** INFO : An Empty Writable Disc Is Recommended For Accurate Results
** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below
** INFO : GET PERFORMANCE Write Speed Descriptor(s)
Descriptor #1 = 5540 KBPS ( 4.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 3324 KBPS ( 2.40x) - [CLV/Non-Pure CAV]
** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command]
** INFO : MODE SENSE Is Obsolete And Not Properly Supported By Some Drives
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 11h (Method 1) - ADIP Information
0000 : 92 0f 04 00 00 03 00 00 00 26 05 3f 00 00 00 00 .........&.?....
0010 : 00 00 01 50 48 49 4c 49 50 53 00 30 34 31 00 39 ...PHILIPS.041.9
0020 : 23 00 9f 7c 5c 02 28 00 9a 7e 70 02 28 00 a0 7b #..|\.(..~p.(..{
0030 : 68 02 28 04 04 20 e0 00 f0 00 00 00 00 00 00 00 h.(.. ..........
0040 : 01 00 17 38 00 28 8b 46 02 2c 00 2e 8a 3a 02 2c ...8.(.F.,...:.,
0050 : 00 2c 8c 3c 02 2c 28 35 50 00 20 00 40 20 00 00 .,.<.,(5P. .@ ..
0060 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0100 : 00 00 ..
Ser ut til at det er philips som har produsert disse platene. Dette er jo et så pass stort selskap at det burde være støtte for dem, eller? :hmm:
Nå begynner jeg å lure på om de var så lurt å kjøpe denne brenneren fra Benq for andre gang. Den sier at den ikke støtter Verbatim sine dvd-rw-plater heller. Kommer bare opp "Not support for this disk" i QScan. :wallbash:
Info-koden for disse platene er :
** INFO : Disc = [DVD+RW:MKM-A02-000]
0010 : 00 00 01 4d 4b 4d 00 00 00 00 00 41 30 32 00 39 ...MKM.....A02.9
0020 : 23 00 94 79 64 02 20 00 9c 7a 6c 02 20 00 9a 7b #..yd. ..zl. ..{
0030 : 68 02 20 12 12 10 e0 00 f0 00 00 00 00 00 00 00 h. .............
0040 : 01 00 17 38 00 29 8b 3e 02 24 00 2d 8e 38 02 24 ...8.).>.$.-.8.$
0050 : 00 2c 90 3e 02 24 44 35 30 e0 f0 30 40 00 00 00 .,.>.$D50..0@...
0100 : 00 00 ..
Er det spilleren/merket brenner som er særdeles kresen, eller er det noe galt med begge brennerene jeg har hatt? :hmm: :
Edit:
Verbatimplatene brant helt fint i en Nec-brenner som sto originalt montert i en halvt år gammel Dell-maskin
Endret av lovemachine
Firmware er en time gammel, så jeg tror ikke det er det.
Testa vanlig dvd+r-plate fra Verbatim. Den ser ut til å virke fint.
** INFO : Disc = [DVD+R:MCC-003-000]
Descriptor #1 = 16620 KBPS (12.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 11080 KBPS ( 8.00x) - [CLV/Non-Pure CAV]
Descriptor #3 = 5540 KBPS ( 4.00x) - [CLV/Non-Pure CAV]
Descriptor #4 = 3324 KBPS ( 2.40x) - [CLV/Non-Pure CAV]
0000 : a1 0f 02 00 00 03 00 00 00 26 05 3f 00 00 00 00 .........&.?....
0010 : 00 00 03 4d 43 43 00 00 00 00 00 30 30 33 00 38 ...MCC.....003.8
0020 : 23 54 37 12 02 42 6e 02 a8 6b 15 15 0b 0b 08 08 #T7..Bn..k......
0030 : 01 19 1b 0c 0c 0c 0d 01 00 00 00 00 00 00 00 00 ................
0040 : 01 00 38 38 02 2d 65 1c 06 2e 23 10 04 1e 1d 01 ..88.-e...#.....
0050 : 00 00 02 2d 65 1c 06 2e 23 10 04 1e 1d 01 00 00 ...-e...#.......
0060 : 02 00 54 70 02 2f 64 67 20 14 0b 0b 01 20 00 00 ..Tp./deg .... ..
0070 : 00 00 02 42 5d 66 20 14 0b 0b 01 20 00 00 00 32 ...B]f .... ...2
0100 : 00 00 ..
QScan godkjenner 8* plata for brenning på 12 speed, ikke på 8-speed, men på 4 og 2,4 er det ok. Rart den ikke godkjenner 8, men sier det er greit med 12?
