[makeway] Skrevet 30. januar 2005 Forfatter Del Skrevet 30. januar 2005 der er hva jeg har i show_news.php: <link href="../../../DOCUME%7E1/ALEXAN%7E1/LOCALS%7E1/Temp/example.css" rel="stylesheet" type="text/css"><?PHP error_reporting (E_ALL ^ E_NOTICE); $cutepath = __FILE__; $cutepath = preg_replace( "'\\\show_news\.php'", "", $cutepath); $cutepath = preg_replace( "'/show_news\.php'", "", $cutepath); require_once("$cutepath/inc/functions.inc.php"); require_once("$cutepath/data/config.php"); //---------------------------------- // Check if we are included by PATH //---------------------------------- if($HTTP_SERVER_VARS["HTTP_ACCEPT"] or $HTTP_SERVER_VARS["HTTP_ACCEPT_CHARSET"] or $HTTP_SERVER_VARS["HTTP_ACCEPT_ENCODING"] or $HTTP_SERVER_VARS["HTTP_CONNECTION"]){ /* do nothing */ } elseif(eregi("show_news.php", $PHP_SELF)){ die("<h4>CuteNews has detected that you are including show_news.php using the URL to this file.<br> This is incorrect and you must include it using the PATH to show_news.php</h4><br>Example:<br> this is <font color=red>WRONG</font> : <?PHP include(\"http://yoursite.com/cutenews/show_news.php\"); ?><br> this is <font color=green>CORRECT</font>: <?PHP include(\"cutenews/show_news.php\"); ?><br> <br><BR>// <font size=2>if you think this message shouldn't be shown, open show_news.php and delete it from there</font>"); } //---------------------------------- // End of the check //---------------------------------- if(!isset($subaction) or $subaction == ""){ $subaction = $POST["subaction"]; } if(!isset($template) or $template == "" or strtolower($template) == "default"){ require_once("$cutepath/data/Default.tpl"); } else{ if(file_exists("$cutepath/data/${template}.tpl")){ require_once("$cutepath/data/${template}.tpl"); } else{ die("Error!<br>the template <b>$template</b> does not exists, note that templates are case sensetive and you must write the name exactly as it is"); } } // Prepare requested categories if(eregi("[a-z]", $category)){ die("<b>Error</b>!<br>CuteNews has detected that you use \$category = \"$category\"; but you can call the categories only with their <b>ID</b> numbers and not with names<br> example:<br><blockquote><?PHP<br>\$category = \"1\";<br>include(\"path/to/show_news.php\");<br>?></blockquote>"); } $category = preg_replace("/ /", "", $category); $tmp_cats_arr = explode(",", $category); foreach($tmp_cats_arr as $key=>$value){ if($value != ""){ $requested_cats[$value] = TRUE; } } if($archive == ""){ $news_file = "$cutepath/data/news.txt"; $comm_file = "$cutepath/data/comments.txt"; }else{ $news_file = "$cutepath/data/archives/$archive.news.arch"; $comm_file = "$cutepath/data/archives/$archive.comments.arch"; } $allow_add_comment = FALSE; $allow_full_story = FALSE; $allow_active_news = FALSE; $allow_comments = FALSE; //<<<------------ Detarime what user want to do if( $CN_HALT != TRUE and $static != TRUE and ($subaction == "showcomments" or $subaction == "showfull" or $subaction == "addcomment") and ((!isset($category) or $category == "") or $requested_cats[$ucat] == TRUE) ){ if($subaction == "addcomment"){ $allow_add_comment = TRUE; $allow_comments = TRUE; } if($subaction == "showcomments") $allow_comments = TRUE; if(($subaction == "showcomments" or $allow_comments == TRUE) and $config_show_full_with_comments == "yes") $allow_full_story = TRUE; if($subaction == "showfull") $allow_full_story = TRUE; if($subaction == "showfull" and $config_show_comments_with_full == "yes") $allow_comments = TRUE; } else{ if($config_reverse_active == "yes"){ $reverse = TRUE; } $allow_active_news = TRUE; } //----------->>> Detarime what user want to do require("$cutepath/inc/shows.inc.php"); unset($static, $template, $requested_cats, $category, $catid, $cat,$reverse, $in_use, $archives_arr, $number, $no_prev, $no_next, $i, $showed, $prev, $used_archives); ?> <!-- cutenews http://cutephp.com/ /-\ aj-fork http://appelsinjuice.org/?vis=cutenews-aj --> Lenke til kommentar https://www.diskusjon.no/topic/369754-aj-fork-endring-av-font-sizecolourbacground/page/2/#findComment-3595415
NisseMannH4X Skrevet 30. januar 2005 Del Skrevet 30. januar 2005 (endret) Men hvorfor poster du hele php koden? Skjønner at du ikke skjønner så mye her, les gjennom hva folk har prøvd å si mange ganger her! Linken til stilsettet må ligge i mellom <head> </head>. Men hvis du bruker et include script for å inkludere show_news.php på sia di (gjør deu det? eller bruker du frames?) burde du legge til <Link rel...> i head'ern til den sia du skal inkludere i! Litt mer ryddig... Altså; hvis du skal ha show_news.php i index'en din, legger du til dette i index.php: <head> <link href="style.css" rel="stylesheet" type="text/css"> </head> Skjønner du nå? Endret 30. januar 2005 av NisseMannH4X Lenke til kommentar https://www.diskusjon.no/topic/369754-aj-fork-endring-av-font-sizecolourbacground/page/2/#findComment-3595600
[makeway] Skrevet 30. januar 2005 Forfatter Del Skrevet 30. januar 2005 haha! skjønner nå vettu! Lenke til kommentar https://www.diskusjon.no/topic/369754-aj-fork-endring-av-font-sizecolourbacground/page/2/#findComment-3597176
NisseMannH4X Skrevet 31. januar 2005 Del Skrevet 31. januar 2005 Gratulerer! Lenke til kommentar https://www.diskusjon.no/topic/369754-aj-fork-endring-av-font-sizecolourbacground/page/2/#findComment-3599099
