ADVARSEL! That's Write 8x DVD-R
Dette er falske TY plater!!!
Unique Disc Identifier : [DVD-R:TYG02]
Disc & Book Type : [DVD-R] - [DVD-R]
Manufacturer Name : [Taiyo Yuden Co. Ltd.]
Manufacturer ID : [TYG02]
Blank Disc Capacity : [2,298,496 Sectors = 4,489.3MB = 4.38GB (4.71GB)]
Recording Speeds : [1x , 2x , 4x]
[6x And Higher Might Not Always Be Detectable]
** WARNING : Some Drives Do Not Return The Entire 'Media Code'-Block
When Dealing with Discs That Are Rated 6x And Higher.
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Present But Cleared
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 00 00 00 00 01 40 c1 fd 9e d8 52 00 02 87 0d 10 [email protected].....
0010 : 66 78 80 00 03 54 59 47 30 32 00 00 04 00 00 00 fx...TYG02......
0020 : 00 00 00 00 05 aa a2 22 22 20 02 00 06 08 0e 11 ......."" ......
0030 : 87 78 80 00 07 88 80 00 00 00 00 00 08 06 13 0d .x..............
0040 : 10 0e 07 00 09 97 07 0d 0b 78 88 00 0a 80 00 00 .........x......
0050 : 00 00 10 00 0b 06 18 17 85 78 75 00 0c d6 89 a8 .........xu.....
0060 : 92 01 20 00 0d 10 00 d0 00 00 00 00 00 00 00 00 .. .............
0070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0100 : 00 00 00 00 ....
[ DVD Identifier - http://DVD.Identifier.CDfreaks.com ]
De første platene i spindelen heg fikk har i tilleg riper og drittpartikler på undersiden som vil gjøre platene uleselige.
Kommer med fullstendig test i løpet av helgen men regner med at disse er så å si 100% DRITT!
Testresultater er her: http://forum.hardware.no/index.php?s=&act=ST&f=62&t=369386
Endret av OC-Freak
Du har ikke testet 4X DVD+R platene demmes? Kjøpte en eske med cover og har bare gode erfaringer med dem...
Enig kjøpte 100stk med cover på komplett før sommeren, og alle har fungert glimrende på flere stasjonære dvd spillere etter å ha blitt brent på min plextor 708a.
Før sommeren var nok disse produsert av ritek med ricoh teknologi - som er meget bra.
Men nå er de optodisc og etter mine erfaringer ikke bra
Kort oppsummering
THATS WRITE før sommern var RICOH plater (bra kvalitet!) 4x +
THATS WRITE ved sommertider 4x - var VANGUARD (sykt ræva, SYKT ræva! 1/5 brenninger på 2x funka OK)
Så skifta THATS WRITE +R til OPTODISC (mye dårligere enn ricoh)
og nå er THATS WRITE fake TY plater?
hahahahahha
Ganske trist at dem bytter dye på denne måten (dvs det som plata egentlig er, ikke merket som står på dem). Man vet jo aldri helt hva man får med mindre man leser forums daglig.
For den vanlige bruker vil dette bety at dem plutselig kan ende opp med et parti drittplater uten å ane noe som helst om det før det er for sent.
Synes virkelig det er på tide at netshopene begynner å ta dette med listing av mediacode under beskrivelse på plater seriøst.
Har selv prøvd å overbevise dem at dette er en god idee, men dem velger totalt å ignorere dette. Så mitt råd er å kun kjøpe plater hos butikker som gir deg mediacode. Eksempler på slike er brenner.no, norwaydisc og pxp.
Jeg ble selv sittende med et stort drittparti med plater en gang, og aldri mer! (uten at jeg selv vet de er dritt da) så handler også hos pxp og norwaydisc.no
Uansett, Det som forundrer meg litt er at THAT'S WRITE tør å putte logoen sin på plater som visstnok er produsert av "Taiyo Yuden Inc" som det står på platen.
Dette er jo rett og slett forfalskning når Taiyo Yuden aldri har vært inne i bildet.
Det må jo få noen konsekvenser for dem?
slik jeg ser det har ikke Komplett gjort noe galt her. De reklamerer ikke for at det er TY plater (som ville ha vært et salgstriks), de selges som vanlig THATS WRITE.
Hvis noen får trouble her er det sluttbruker og Thats Write. Ikke komplett :-)
Det er jo bare drittmerker som bruker falske TY :roll:
Det er med andre ord ikke noen bombe.
Hvis noen ikke visste at That's write (spesielt DVD-R) var drittmerke fra før, så vet dere det nå.
Et godt tegn på et drittmerke er at de bytter produsent ofte. Dette er til de grader tilfellet med That's write.
Jeg kan ikke skjønne at det ikke er påbudt med info om den egentlige produsenten på pakken og ved netthandel :hmm:
Dette gjør at man ikke vet hva man får.
Så derfor er det bare å holde seg unna slike merker.
Lager en ny tråd senere med test resultater - men dette er noe av det VÆRSTE!!! jeg har vært borti på lenge!
BenQ DW1620A= write error
Plextor PX-712A = finner ikke platene en gang
Plextor PX-716A = "servo spindle failure"
NEC ND-2510A = Write error.
Tror vi har en ny "VANGUARD" på gang her ja!
Jeg personlig har kun gode erfaringer med That's Write (dog DVD+R plater) 4,7GB 4x.
Har vel brent rundt 450 stykker, både med video, data og musikk. Har hatt rundt 10 feilbrenninger.
Noen av platene har gått i ettertid, men det er heller pga en dårlig brenner ejg hadde til å begynne med. (Fujitsu-Siemens laptop brenner)
Bruker nå en Nec 2500, og har hatt maks 3 feilbrenninger på denne.
Jeg e storfornøyd med That's Write's plater av denne sorten.
Men det har kanskje ikke så mye å gjøre med de nye platene å gjøre, ville bare meddele erfaringen med den andre sorten..
D
