ny pc eller oppgradering - hjelp
hei! Lurer på om noen kan hjelpe meg: jeg skal ha en ny gaming-pc eller oppgardere den pc jeg allerede har. har skjerm,mus,tastatur fra før av. vil bruke max 8000 kr på de nye komponentene/pc. spillene jeg skal spille er f.eks half-life,sims,doom,warcraft,tycoon osv., og jeg vil gjerne ha en bra spille-pc...
har denne pc med komponenter nå (kan nesten ikke noe om pc, så jeg bare poster hele greia):
Description Your Results
Brand/Model Compaq Compaq PC
Type Desktop
Serial Number 8044FPP712BT
BIOS Compaq 786K1 10/12/2000
System Board Compaq 06E4h None
Class Vendor Product Code
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Ports ECP Printer Port (LPT1)
USB Microsoft USB Printing Support
printer Canon Canon i560
Ports Communications Port (COM1)
fdc Standard Floppy Disk Controller
Mouse Microsoft PS/2 Compatible Mouse
System Microsoft Microsoft ACPI-Compliant System
Monitor COMPAQ COMPAQ MV740 Color Monitor
FloppyDisk Floppy disk drive
CDROM COMPAQ DVD-ROM DRD8120B
DiskDrive WDC WD200EB-11BHF0
Unknown Network Controller 28
DISPLAY NVIDIA NVIDIA RIVA TNT2 Model 64 Pro
Net Realtek Semiconductor Corp. Realtek RTL8139/810x Family Fast Ethernet NIC
hdc VIA Technologies, Inc. VIA Bus Master IDE Controller
System VIA VIA Tech PCI to ISA Bridge
System VIA VIA Tech CPU to PCI bridge
USB VIA Technologies VIA Rev 5 or later USB Universal Host Controller
System VIA VIA Tech Power Management Controller
Media Analog Devices, Inc. SoundMAX Integrated Digital Audio
System VIA VIA Tech CPU to AGP controller
hdc Primary IDE Channel
hdc Secondary IDE Channel
Computer Advanced Configuration and Power Interface (ACPI) PC
Net Microsoft Direct Parallel
Disk Drives
Letters Model Serial Removable Details
C WDC WD200EB-11BHF0 Unknown No DMA
Monitors
Model Max Resolution Viewable Area Serial Manufactured
COMPAQ MV740 Color Monitor 1280 x 1024 33 x 25 cm 1 October 2000
Brand/Model AMD Duron
Nominal Clock Speed 750 MHz
Measured Clock Speed 750 MHz
External Clock Speed 100 MHz
CPU Load 44%
Speed Rating 1991 (95% of 895 similar)
Memory ConfigurationDescription Results
RAM installed 128 MB
Windows RAM 128 MB
Total RAM slots 3
Available RAM slots 1
Max RAM module size 0 MB
Memory Type 64+64+0;DIMM,DRAM,|Synchronous;T16
Speed Rating 1613 MB/s (92% of 895 similar)
Description Drive C
Partition format FAT32
Cluster size 16 KB
Drive label No Label
Size 19082 MB
Free space 1547 MB (8%)
Junk files 496 MB (3%)
Data fragmentation 60%
File fragmentation 7%
Uncached speed 6 MB/s (32%)
Disk DrivesHere are the physical disk drives that we have detected on your system:
Drive 0
Drive letters C
Removable media No
Brand/Model WDC WD200EB-11BHF0
IDE details DMA
Serial number
Revision level
Here are the hard disk controllers that we have detected on your system:
Vendor Product
Primary IDE Channel
CD/DVD DrivesHere are the CD and DVD drives that we have detected on your system:
Model Type Max Read Speed Max Write Speed
COMPAQ DVD-ROM DRD8120B DVD-ROM 7040 KB/s (40X) N/A
Brand/Model NVIDIA RIVA TNT2 Model 64 Pro
Resolution 1280x1024 pixels
Colors 16 million
DirectX version 5.3.0000001.0904 built by: private/Lab06_dev(DXBLD
OpenGL version 5.1.2600.0 (xpclient.010817-1148)
Acceleration options Enabled
Performance 38.64 MP/s (No similar CPU/MHz/video)
Kan noen hjelpe meg med hva jeg trenger å gjøre for å opgradere pc min for inntil 8 tusen? eller burde jeg bare kjøpe en ny pc fra komplett, en jeg kan velge komponenter til selv? Eventuelt hvilke komponenter bør jegvelge til spilling?
denne pc-en: http://www.komplett.no/k/ci.asp?sku=10080
eller: http://www.komplett.no/k/ci.asp?sku=10033
har windows xp på compaq-en så jeg kan vel bare overføre den og alt annet jeg har på compaq-en til den nye harddisken? slipper vel å kjøpe xp på nytt?
håper det er noen flinke her!! :!:
