Konvertere .wmv/.mpg/o.l. til .3gp ?
toth
Ah.. Google er en fin ting.. :blush:
thanks to gromkov:
_________________________________________
Question:
How can I convert all or any of the media files out there to 3GP format?
Answer:
The most easy way: download Nokia Multimedia Player with 3GP support.
Download it from here: http://www.nokia.com/nokia/0,8764,42291,00.html (8MB)
This is normal video player for PC platform (Windows OS), but it has several additional functions (conversion to 3gp format).
1) Download and install player.
2) Launch Nokia Multimedia Player. Open your video file (avi or mpg).
3) Press File -> Save as...
4) Enter filename of your 3gp file, and choose resolution and size limit:
MMS 64KB, 128*96
MMS 95KB, 128*96
MMS 95KB, 176*144
Custom 200KB, 128*96
Custom 200KB, 176*144
Custom 300KB, 128*96
Custom 300KB, 176*144
No size limit, 128*96
No size limit, 176*144
5) Click Save. File converted. That's all!
Du kan også bruke mpegable X4 live :)
Jeg har prøvd mpegable men jeg får en ekstra ramme rundt filmen som gjør at bildet blir enda mindre en det trenger. Vet du hvordan man blir kvitt denne rammen? Versjonen jeg fant var gratis, mulig det er derfor, men finnes det da noen bedre versjoner der ute?
