program som automatisk reeboter pc'en
Jepp, det er nesten det samme i XP.
Usage: shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "c
omment"] [-d up:xx:yy]
        No args                Display this message (same as -?)
        -i                      Display GUI interface, must be the first option
        -l                      Log off (cannot be used with -m option)
        -s                      Shutdown the computer
        -r                      Shutdown and restart the computer
        -a                      Abort a system shutdown
        -m \\computername      Remote computer to shutdown/restart/abort
        -t xx                  Set timeout for shutdown to xx seconds
        -c "comment"            Shutdown comment (maximum of 127 haracters)
        -f                      Forces running applications to close without warning
        -d [p]:xx:yy        The reason code for the shutdown
                                u is the user code
                                p is a planned shutdown code
                                xx is the major reason code (positive integer less than 256)
                                yy is the minor reason code (positive integer less than 65536)
Men som sagt, det er en fordel å fortelle hva slags OS du kjører.
For automatikk kan du bruke AT som f.eks her: (windows)
AT 22:00 /interactive /every:M,T,W,Th,F,S,Su "shutdown -r -f -t 0"
Når det gjelder å starte maskinen igjen så har mange (alle?) maskiner med AWARD bios mulighet for oppstart på gitt tidspunkt hver X.
