Torrent program som kan fjenstyres.
Pasient
Spyware? Sure?
eXeem is a brand new Peer-To-Peer program, which is based on the BitTorrent idea. eXeem eliminates the need for trackers as nodes in the program will be taking their role. eXeem also features easy publication of files to the network as well as a rating and comments system. eXeem contains NO SPYWARE. eXeem is free and is ad-supported. eXeem is currently still in its beta testing phase, which means that the network might not be completely stable yet. You are still very welcome to give eXeem a try and see how it is different from other Peer-To-Peer programs.
Fra eXeems hjemmeside
Edit:
tja....
http://filesharingplace.com/forums/index.php?showtopic=3238
EDIT2:
http://www.zeropaid.com/news/articles/auto/01062005e.php
Cydoor møkk!
Gå for LITE!!!!
Endret av Okay
