har ødelagt gl-støtten. trenger litt gode forslag
ways
ting fungerte ikke helt da jeg prøvde meg på å installere ATIs nye drivere. nå funker ikke openGLprogrammer på maskinen lengre. dette før jeg om jeg prøver å reinstallere:
lars@aotearoa:/usr/share/gdesklets/Displays $ sudo apt-get install fglrx-driver Password:
Reading Package Lists... Done
Building Dependency Tree... Done
The following NEW packages will be installed:
 fglrx-driver
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 0B/2564kB of archives.
After unpacking 7836kB of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 93040 files and directories currently installed.)
Unpacking fglrx-driver (from .../fglrx-driver_2.6.8.1.3-5_i386.deb) ...
Leaving `diversion of /usr/X11R6/lib/libGL.so.1.2 to /usr/share/fglrx/diversions/libGL.so.1.2 by fglrx-driver'
dpkg: error processing /var/cache/apt/archives/fglrx-driver_2.6.8.1.3-5_i386.deb (--unpack):
trying to overwrite `/usr/X11R6/bin/fgl_glxgears', which is also in package fglrx-4-3-0
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Prøv å avinstallere fglrx-4-3-0 først med apt-get remove fglrx-4-3-0,evt. dpkg -r fglrx-4-3-0.
hm. trodde jeg hadde prøvd det..? men det ser ut til at det gikk bra da:
lars@aotearoa:~/musikk $ sudo apt-get install fglrx-driver
 fglrx-driver
(Reading database ... 92954 files and directories currently installed.)
Setting up fglrx-driver (2.6.8.1.3-5) ...
men ikke helt ferdig enda:
lars@aotearoa:~/musikk $ kaffeine: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
hvilken pakke inneholder libGL.so? har gått gjennom ati-howto'en uten å finne løsningen..
