Trenger hjelp med html inne i echo
Er det mulig å få dette til å faktisk fungere:
require_once "/home/ingardje/public_html/pub/ibp/ipbsdk_class.inc.php/";
$SDK =& new IPBSDK();
// Grab language preference or use English
$adv_info = $SDK->get_advinfo();
$language_pref = $adv_info['language'];
if (!$language_pref){ $language_pref = "no"; }
require_once "/home/ingardje/public_html/forum/lang/".$language_pref."/lang_global.php";
// START MEMBERBAR
$boardurl = "http://www.purloin.net/forum"; // Define Board URL here for usage later
if ($SDK->is_loggedin()) {
// We're logged in. Retrieve member info
$info = $SDK->get_info();
// Generate Bar Content
$member_name = $info['name'];
$extralinks = "";
       $lang_msg_new = sprintf($lang['msg_new'], $SDK->get_num_new_pms());
// Display Member Bar
echo '<ul>
           <li><span class="loggedinas">'.$lang['logged_in_as'].'</span> '.$member_name.'</li>
 	<li><a href="http://www.purloin.net/forum/index.php?act=Msg&CODE=01">{$msg[TEXT]}</a></li>
           <li><a href="'.$boardurl.'/index.php?act=UserCP&CODE=00" title="'.$lang['cp_tool_tip'].'">'.$lang['your_cp'].'</a></b> </li>
         <li><a href="'.$boardurl.'/index.php?act=Msg&CODE=01">'.$lang_msg_new.'</a>
<li><a href="javascript:buddy_pop();" title="{ibf.lang.bb_tool_tip}">Min assistent</a></li>
   </ul>
   <a href="'.$boardurl.'/index.php?act=Login&CODE=03">'.$lang['log_out'].'</a>';
else {
// Display the Guest Bar
echo ' <form id="loginform" action="http://www.purloin.net/forum/index.php?act=Login&CODE=01" method="post" name="LOGIN">
    <fieldset>
    <label accesskey="B" for="username">Brukernavn</label>
          <input id="username" class="form-text" name="UserName" onfocus="this.value=''" />
          <label accesskey="P" for="password">Passord</label>
          <input id="password" type="password" class="form-text" name="PassWord" onfocus="this.value=''" />
          <input type="submit" value="Logg inn" class="form-submit" />
    </fieldset>
          </form>';
// END OF MEMBERBAR
Problemet er at jeg ikke vet hvordan å skrive html, slik at det fungerer, inne i echo ''.
I tillegg er det jo flere variabler (?) inne i selve html'en. Noen som hadde giddet å se på dette?
Men, kan du tenke deg hvorfor denne
<form id="loginform" action="http://www.purloin.net/forum/index.php?act=Login&CODE=01" method="post" name="LOGIN"><fieldset><label accesskey="B" for="username">Brukernavn</label><input id="username" class="form-text" name="UserName" /><label accesskey="P" for="password">Passord</label><input id="password" type="password" class="form-text" name="PassWord" /><input type="submit" value="Logg inn" class="form-submit" /></fieldset></form>
ikke kommer frem, når den er plassert i en echo?
Og, har i tillegg plassert dette
//includes ibp
ob_start();
include "http://pub.purloin.net/ibp/memberbar_int.php";
$PAGE->set_property('menu',ob_get_clean());
slik for inkludering. Denne ligger da i hovedfila for CMS'et, da det bygger på et templatesystem, og man kan ikke plassere <?php inne i templatefilene, fordi templatet er jo inkludert i hovedfila. <? <? går ikke :) Hvis du skjønner.
Jeg har flere slike, og de fungerer, men ikke akkurat det scriptet vist i første topic. Vet du om noen årsaker til dette, eller trenger du mer info?
Ble kanskje litt vagt dette. Hovedpoenget er at jeg vil ha det første scriptet vist i hovedfila. Men det skjer ingeting, selv om det fungerer hvis man går direkte til det ikluderte scriptet. http://pub.purloin.net/ibp/memberbar_int.php . (du må være inlogget i forumet for å vise innholdet i den fila, jamfør problemet med form og echo!)
Huff, og nei og nei.
Edit: Vent nå litt, <?php include "http://pub.purloin.net/ibp/memberbar_int.php"; ?> funker ikke. Har prøvd i en enkeltstående fil. Der er jo problemet da. Hvorfor fungerer ikke det da?
Endret av Ingardj
Kan det være fordi du kjører med " " inni koden?
Kjører du echo "<html kode="attributer" med="">";
blir koden avbrutt ved hver ", og da begynner ting å feile.
Skal du ikke ha noen variabler inni koden, kan du kjøre ut koden med ' istedenfor ", eller escape " inni HTML-koden med \"
