Du kan modde DFI nF4 Ultra til SLI!
eskarls
Leste følgende på anandtech.com!!
It really did not come as a surprise that nForce4 Ultra and nForce4 SLI are the same chipset with some capabilities in Ultra turned off. We have seen many cases over the years in which a manufacturer has one CPU-die or one chipset come off a production line, which are then differentiated with laser cuts or some other means of controlling speed or capabilities. What did come as a surprise is how very easy it is to reverse the process - to turn the nForce4 Ultra into the higher-priced and better-performing nForce4 SLI. This is an extremely easy mod for almost anyone.
We suspect that there is more to the story, however, than just the fact that the chip can be modded to be seen by the system as being an SLI chip. nVidia design specifications actually dictate a different board design for Ultra than for SLI. We stated early in this article that DFI is using the exact same board for their SLI and Ultra versions of nForce4. We know that the mod works on the DFI LANParty UT nF4 Ultra-D, but we did not have any other dual video slot Ultra board on which to test the SLI mod. We are expecting the Epox board any day, and we will certainly let you know if the SLI mod works on that board too.
Blir vel enda en grunn til å kjøpe DFI :)
