Canal Digital kabel Internett, responstid ?
CD 2050/2050 i trondheim
PING 193.71.196.40 (193.71.196.40): 56 data bytes
64 bytes from 193.71.196.40: icmp_seq=0 ttl=57 time=16.3 ms
64 bytes from 193.71.196.40: icmp_seq=1 ttl=57 time=17.6 ms
64 bytes from 193.71.196.40: icmp_seq=2 ttl=57 time=19.1 ms
64 bytes from 193.71.196.40: icmp_seq=3 ttl=57 time=17.2 ms
64 bytes from 193.71.196.40: icmp_seq=4 ttl=57 time=19.0 ms
64 bytes from 193.71.196.40: icmp_seq=5 ttl=57 time=18.2 ms
64 bytes from 193.71.196.40: icmp_seq=6 ttl=57 time=18.6 ms
64 bytes from 193.71.196.40: icmp_seq=7 ttl=57 time=16.8 ms
64 bytes from 193.71.196.40: icmp_seq=8 ttl=57 time=16.8 ms
64 bytes from 193.71.196.40: icmp_seq=9 ttl=57 time=14.1 ms
--- 193.71.196.40 ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 14.1/17.3/19.1 ms
fra 2000/2000 Canal Digital kabel i sandefjord
Pinging 193.71.196.40 with 32 bytes of data:
Reply from 193.71.196.40: bytes=32 time=15ms TTL=57
Reply from 193.71.196.40: bytes=32 time=16ms TTL=57
Kunne du være så vennlig å pinge ditt første hopp etter modemet ditt.
Er litt nyskjerrig da jeg mener min er for ustabil, og mistenker at det er noe feil med modemet (linjer og alt er kontrolert og funnet i orden)
