Kjappere firefox til å laste sider
Tydeus
Prøvde akkurat noe jeg fant på nettet for å laste sider mye kjappere og da mener jeg MYE kjappere.
Gjør som følger:
How To Speed Up Firefox
Here´s something for broadband people that will really speed Firefox up:
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
network.http.pipelining
network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer.
Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
4. Restart your browser.
If you´re using a broadband connection you´ll load pages MUCH faster now!
Dette funker fett...laster nå sider slik som VG.no på under 1 sec :w00t:
hvis alle satte max request til 30, hadde serverene sliti noe inni granskauen. Er forresten en tråd, om ikke flere, om dette her på forumet fra før.
Endret av Dell_Inspiron
Riktig. :yes:
Jeg bruker ikke denne metoden, nettopp pga. serverene blir så mye emre belastet.
Gjest
