K700i R2AE033 firmware på SEUS
bidz
Da er den nye firmware'n på Sony Ericsson's Update Service. Updata nettopp med DSS-25. Mye kjappere menyer, quicksearch i telefonlista, noe mindre støy på bilder tatt i dårlig belysning (ny Camera Driver 3.10), etc. + mange bugfixes;
R2AE033
- Faster overal speed
- Search function disabled in Asian firmware (Far east only?).
- Search function in phonebook upgraded for non-Asian firmware (C doesn't delete Contact, but letters you've entered, cursor cancels search)
- 900 ms+ delay on answering a call before the microphone was switched on has been fixed.
- Display Smileys in MMS/Browser
- Support of Apple ITunes format .m4a (=.mp4) including speech encoding format AAC
- Stopwatch no longer goes into backlight off mode or sleep mode
- Noise in HCA-20 car handsfree is gone
- The signal strength indicator has changed. Now signal is lowered by 1 bar at a time. Signal is raised to 5 bars if a strong signal is detected.
- Various crashes fixed (e.g. when music is playing an an alarm goes off)
- Various Java / Java 3D fixes
- Various browser / WAP / CSS fixes
- Various fixes to the Calendar application
- Various layout / font size fixes
- Updated Camera driver to change the default flicker compensation mode from 50 Hz to automatic.
- JBenchmark1: 2129
- Jbenchmark2: 125
- Software versions:
LCD 200406041
Camera 3.10
ITP CXC 125 813 R1S
