Superslask Skrevet 10. februar 2006 Rapporter Del Skrevet 10. februar 2006 Kopierte fra min egen tråd på guildforumet under druid seksjonen: To buff your target with the highest rank of MotW that his level can take: /script r=7; l={1,10,20,30,40,50,60}; t=UnitLevel("target"); if (UnitExists("target")) then for i=r,1,-1 do if (t>=l[i]-10) then CastSpellByName("Mark of The Wild(Rank "..i..")"); break;end;end; else CastSpellByName("Mark of The Wild(Rank "..r..")"); end Same thing for thorns: /script r=6; l={6,14,24,34,44,54}; t=UnitLevel("target"); if (UnitExists("target")) then for i=r,1,-1 do if (t>=l[i]-10) then CastSpellByName("Thorns(Rank "..i..")"); break;end;end; else CastSpellByName("Thorns(Rank "..r..")"); end I have exanged the buffs on my hotbars with these macroes. SelfCast addons don't tend to work with these, but it's only 2 buffs. To have Nature's Swiftness and Healing Touch in one button, that means you push one button and instaheal yourself: /script CastSpellByName("Nature's Swiftness"); /script SpellStopCasting(); /script TargetUnit("player"); /script CastSpellByName("Healing Touch(Rank 10)"); /script TargetLastTarget(); This heals yourself, but if you want to do that to your current target: /script CastSpellByName("Nature's Swiftness"); /script SpellStopCasting(); /script CastSpellByName("Healing Touch(Rank 10)"); For some usefull macroes to prevent us innervating / ressurecting same player: /cast innervate /5 %t has been Innervated! /cast rebirth /5 ressing %t Note that /5 is my adadruid channel, for you it might aswell be 6 or 7. A Healing Touch macro made by Velanth(atleast posted) which heals you with the right rank of Healing Touch according to your current health: /script p="player";d=UnitHealthMax(p)-UnitHealth(p);H={44,103,224,413,647,838,1053,1347,1699,2107};for i=10,1,-1 do if d>H[i] then TargetUnit(p);CastSpellByName("Healing Touch(Rank "..i..")");TargetLastTarget();break;end;end; I never use this however, this is because I always choose from different ranks from who and when I'm healing. And for my freeriding macro. I use CTRA emergency monitor(you find it under options somewhere) and an inrange addon which only shows people on that monitor if they are in range. Now, we need to target the first member on that list(thanks Foosi), and then we can continiue with /cast blabla: /script CT_RA_Emergency_TargetMember(1); /cast Healing Touch(rank 4) Optional is to add /script ClearTarget(); at last to clear your target. I have 2 versions of this macro, difference is only which rank of Healing Touch. Note that this is ONLY valuable for use on trashmobs, as on bosses you can't slack off with easy healing. The only exception I have found is on Firemaw, healing rogues. They now have a route which will always keep them in line of sight of you(if you are on rogue duty), and they will steadily loose health. Using this macro here makes it so much easier. But again, DO NOT use this macro elsewhere as it makes you lazy and eventually makes you a bad healer. One thing I want you to make, is the macroes which tells who you innervate and ressurect. More then once have I and others used 2 innervates on same guy, and even 2 rebirths. Thanks to those who made some of the macroes. Edit: Cropped from Klydan: /script var = 0 for i=1,16 do if UnitBuff("target", i) then if string.find(UnitBuff("target", i), "Rejuvination") then var = 1 end end end if var == 0 then CastSpellByName("Rejuvination") end Checks if target has Rejuv on him/her before casting. If he/she has that, it doesen't cast Rejuvination. Lenke til kommentar
Dunderklumpen Skrevet 14. februar 2006 Rapporter Del Skrevet 14. februar 2006 Noen som vet om en macro sånn ca: /target /cast faerie fire rank X funker mot rogues? Jeg mener, jeg kan jo se de akkurat før de cheap shotter (er druid med rank 7 gloves atm) men rekker ikke å "Tabbe" de og kaste før de cheap shotter etc... trenger jeg eventuelt noe etter /Target eller holder det? Tenkte det funket akkurat som Tab (select nearest enemy). Vet ikke om noen har postet det, men jeg har en jævlig fin healing macro på Broodlord og Ebonroc hvor man konstant bytter MT og de tar massiv skade. (ok, fant den ikke, men hvis noen trenger kan jeg poste den) Lenke til kommentar
jinriksha Skrevet 15. februar 2006 Rapporter Del Skrevet 15. februar 2006 kan noen lage meg macro der den skifter fra 2 daggers til fiskestang og fra fiskestang tilbake til 2 dagers..? Lenke til kommentar
Sjoeoerret Skrevet 15. februar 2006 Rapporter Del Skrevet 15. februar 2006 Prøver ålage en macro som skal få meg til å kaste bloodrage så Battleshout.. den ser slik ut men virker ikke. :/ /cast Bloodrage /cast Battle Shout(rank 2) Lenke til kommentar
Killerquo Skrevet 15. februar 2006 Rapporter Del Skrevet 15. februar 2006 Er det mulig å lage en macro som åpner chat-linja med forhåndsinnsatt skrift som: *Low whisper* | [strek viser blinkende strek der neste tegn skal skrives] , *Harsh voice* | etc? Spiller på RP-server, og innimellom er det vanskelig å vite hvilken måte en person snakker til deg på, og da om man har en del ferdiglagde istedet for å skrive inn, og så ctrl+c ctrl+v, og da rett etter igjen skifte til en annen måte å snakke på er det tungvint... Lenke til kommentar
royale Skrevet 17. februar 2006 Rapporter Del Skrevet 17. februar 2006 /y And I will strike down upon thee with great vengeance and furious anger those who attempt to poison and destroy my brothers. And you will know I am the Lord when I lay my vengeance upon you, navnet på target. Hva skal jeg sette inn der? Lenke til kommentar
Edmund Blackadder Skrevet 18. februar 2006 Rapporter Del Skrevet 18. februar 2006 Ehm navnet på target? Det er vel %t Lenke til kommentar
royale Skrevet 18. februar 2006 Rapporter Del Skrevet 18. februar 2006 OK, skal prøve det. Lenke til kommentar
Killerquo Skrevet 20. februar 2006 Rapporter Del Skrevet 20. februar 2006 Er det mulig å lage en macro som åpner chat-linja med forhåndsinnsatt skrift som: *Low whisper* | [strek viser blinkende strek der neste tegn skal skrives] , *Harsh voice* | etc? Spiller på RP-server, og innimellom er det vanskelig å vite hvilken måte en person snakker til deg på, og da om man har en del ferdiglagde istedet for å skrive inn, og så ctrl+c ctrl+v, og da rett etter igjen skifte til en annen måte å snakke på er det tungvint... 5609958[/snapback] Ingen som vet? Blir jo en macro omtrent som /s *low whisper* [insert text] bare at jeg vil at macroen skal bare få opp chaten med eksempelvis *low whisper* skrevet inn alerede slik at jeg kan fortsette å skrive. Lenke til kommentar
.Marcus Skrevet 22. februar 2006 Rapporter Del Skrevet 22. februar 2006 Jeg har prøvd å eksperimentere med en polymorph (sheep) macro. [..] /script S=UnitSex("target"); L=UnitLevel("target");N=UnitName("target"); U=UnitCreatureType("target"); if(N~=nil) then if (U=="Humanoid" or U=="Beast") then if S then T="Polymorphing Female Lvl[["..L .. N .. "]]!!"; CastSpellByName("Polymorph(Rank 3)");end; if(N~=nil) then if (U=="Humanoid" or U=="Beast") then if (S~=1) then T="Polymorphing Male Lvl[["..L .. N .. "]]!!"; CastSpellByName("Polymorph(Rank 3)");end; if ((N=nil) or (U~="Humanoid" and U~="Beast")) then T="Now Sheeping, " .. N .. " is " .. U; end; SendChatMessage(T,"party"); end; 3730165[/snapback] Er ikke denne langt over 255 tegn? 5512877[/snapback] 545 med spaces. Lenke til kommentar
værdama Skrevet 23. februar 2006 Rapporter Del Skrevet 23. februar 2006 hvordan kan jeg få til og bruke Zandalarien hero charm og Talisman of ephmeral power og så AP.. presence of mind og så Pyroblast? kan noen si hvordan jeg kan få laget dette? takk Lenke til kommentar
shizz kebab Skrevet 25. februar 2006 Rapporter Del Skrevet 25. februar 2006 Jeg har prøvd å eksperimentere med en polymorph (sheep) macro. [..] /script S=UnitSex("target"); L=UnitLevel("target");N=UnitName("target"); U=UnitCreatureType("target"); if(N~=nil) then if (U=="Humanoid" or U=="Beast") then if S then T="Polymorphing Female Lvl[["..L .. N .. "]]!!"; CastSpellByName("Polymorph(Rank 3)");end; if(N~=nil) then if (U=="Humanoid" or U=="Beast") then if (S~=1) then T="Polymorphing Male Lvl[["..L .. N .. "]]!!"; CastSpellByName("Polymorph(Rank 3)");end; if ((N=nil) or (U~="Humanoid" and U~="Beast")) then T="Now Sheeping, " .. N .. " is " .. U; end; SendChatMessage(T,"party"); end; 3730165[/snapback] Er ikke denne langt over 255 tegn? 5512877[/snapback] 545 med spaces. 5650344[/snapback] Er en addon som heter SuperMacro elns som gjør det mulig for mange flere tegn. Lenke til kommentar
dedLy_sCoRpIoN Skrevet 2. mars 2006 Rapporter Del Skrevet 2. mars 2006 trenger ein WTS macro. Vil ha ein macro som eg kan bruke i trade chat, men eg får ikkje til å linke til items, slik at du kan shift-klikke på de, og få opp attributes ol på itemet, funker ikkje med ctrl + c. Kordan løyse dette problemet? Lenke til kommentar
yuo are smart Skrevet 7. mars 2006 Rapporter Del Skrevet 7. mars 2006 (endret) Kan hende det har blitt tatt opp før, men hvordan binder jeg trinkets til en macro? som ZHC og ToEP med Arcane power? EDIT: Ingen nei Endret 7. mars 2006 av Bamboocha Lenke til kommentar
Turboleif Skrevet 10. mars 2006 Rapporter Del Skrevet 10. mars 2006 På pet-baren til Impen min så har jeg mistet "Phase shift" den har forsvunnet fra pet-baren.. Er det mulig å få en macro for denne (phase shift), og hva må skrives? Lenke til kommentar
ahpadt Skrevet 10. mars 2006 Rapporter Del Skrevet 10. mars 2006 Kan hende det har blitt tatt opp før, men hvordan binder jeg trinkets til en macro? som ZHC og ToEP med Arcane power? EDIT: Ingen nei 5713895[/snapback] /script UseInventoryItem(GetInventorySlotInfo("Trinket0Slot")); /script SpellStopCasting(); /script UseInventoryItem(GetInventorySlotInfo("Trinket1Slot")); /script SpellStopCasting(); /cast Arcane Power Lenke til kommentar
yuo are smart Skrevet 10. mars 2006 Rapporter Del Skrevet 10. mars 2006 Takk! Den funka på tide å eie allies Lenke til kommentar
shizz kebab Skrevet 13. mars 2006 Rapporter Del Skrevet 13. mars 2006 Trenger macro til å først kaste Presence of Mind og så Frostbolt..anyone? Lenke til kommentar
Edmund Blackadder Skrevet 13. mars 2006 Rapporter Del Skrevet 13. mars 2006 (endret) Edit: Jeg trodde altså at Presence of mind hadde global cooldown som den ikke hadde så det blir istedenfor noe slik som: /script CastSpellByName("Presence of mind"); /script SpellStopCasting(); /script CastSpellByName("Frostbolt(Rank ??)"); Correct me if Im wrong. Endret 13. mars 2006 av Edmund Blackadder Lenke til kommentar
Dynejonas Skrevet 14. mars 2006 Rapporter Del Skrevet 14. mars 2006 På pet-baren til Impen min så har jeg mistet "Phase shift" den har forsvunnet fra pet-baren.. Er det mulig å få en macro for denne (phase shift), og hva må skrives? 5733443[/snapback] KK. Det du må gjøre er: Når du har impen ute, trykker du "c" så er det en tap som heter pet. Der vil du finne alle fire spells som din pet har. Lenke til kommentar
