Cursed Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 jeg har søkt litt etter svar, men fant ikke noe. har ingen peiling på hva som er feilen, og derfor legger jeg den her. når jeg trykker på jedi knight 2, starter spillet, men den kommer ikke inn i menyen. etter ca. 3 sek hopper den ut i et vindu og øverst i vinduet står det 'GLW_StartOpenGL() - Could not load OpenGL subsystem.' dette blinker rødt litt lengre nede står det: JK2: v1.02a win-x86 Mar 4 2002 Initialising zone memory ..... ----- FS_Startup ----- Current search path: D:SpillStar Wars - Jedi Knight II - Jedi OutcastGameDatabaseassets1.pk3 (8011 files) D:SpillStar Wars - Jedi Knight II - Jedi OutcastGameDatabaseassets0.pk3 (6674 files) D:SpillStar Wars - Jedi Knight II - Jedi OutcastGameData/base ---------------------- 14685 files in pk3 files execing default.cfg couldn't exec autoexec.cfg ...detecting CPU, found Intel Pentium III ------- Input Initialization ------- Skipping check for DirectInput Joystick is not active. ------------------------------------ ------- Force Feedback Initialization ------- ...inhibited, not initializing ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- --- Common Initialization Complete --- Working directory: D:SpillStar Wars - Jedi Knight II - Jedi OutcastGameData ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'D:WINDOWSSystem32opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem har noen noe peiling på hva jeg skal gjøre? jeg vil spille JK2.. PS. jeg kan spille det, har spilt det før i 98SE. _________________ PIII 500MHz 256 MB SDRAM Riva TNT - 8MB SDRAM! 12 GB HD 31,4 GB Samsung HD Windows XP Pro/Windows 98 SE Får hele 814 i 3DMark :smile: [ Denne Melding var redigert av: Cursed på 2002-06-12 17:34 ] Lenke til kommentar
Olsenhower Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Jeg fikk det samme problemet da jeg skiftet skjermkort fra GF2MX til GF4Ti4400. Problemet løste seg selv etter å ha reinstallert spillet. Hvis ikke det hjelper, så er kanskje skjermkortet ditt noe utdatert. Minstekravet er jo 16Mb. Lenke til kommentar
Cursed Skrevet 12. juni 2002 Forfatter Del Skrevet 12. juni 2002 jeg kan kjøre spillet. har kjørt det før i 98SE. prøver å reinstallere det. PS. har bestilt nytt skjermkort som jeg regner med holder i 6-12 måneder. (GF2 MX400 32MB) [ Denne Melding var redigert av: Cursed på 2002-06-12 17:37 ] Lenke til kommentar
Olsenhower Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Så det klikker i XP? Har du prøvd reinstallasjon? edit: han prøver reinstallasjon :smile: _________________ tsk, tsk... [ Denne Melding var redigert av: zuperMensch på 2002-06-12 17:37 ] Lenke til kommentar
steinih Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Du har ikke akkurat et skjermkort som vil takle det spillet da! Mulig det er det som er problemet... Får du spille andre tilsvarende krevende spill på den maskinen da? /steinih :smile: Lenke til kommentar
Cursed Skrevet 12. juni 2002 Forfatter Del Skrevet 12. juni 2002 Quote: Den 2002-06-12 17:37, steinih skrev:Du har ikke akkurat et skjermkort som vil takle det spillet da! Mulig det er det som er problemet... Får du spille andre tilsvarende krevende spill på den maskinen da?/steinih :smile: igjen, jeg har spilt det før på samme maskinen. Lenke til kommentar
steinih Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Greit at du har spilt det før, men husk at du har XP nå da og ikke 98se! Har du fått spille noen andre tilsvarende krevende spill (igjen) i XP da? Fikk samme feilmelding en gang og da måtte jeg oppdatere driverne til skjermkortet. Bruker du standarddrivere eller om du har installert noe selv? /steinih :smile: Lenke til kommentar
Cursed Skrevet 12. juni 2002 Forfatter Del Skrevet 12. juni 2002 bruker detonator 28.32 (tror jeg?) driverne til nvidia, og jeg har bare prøvd empire earth og anarchy online i xp på min pc. de funker fint. (fint og fint..all grafikken er nesten helt nede..) edit: skrivefeil PS. det hjelp ikke å reinstallere det [ Denne Melding var redigert av: Cursed på 2002-06-12 18:07 ] Lenke til kommentar
Zamoht Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Prøv med noen eldre drivere... Du får ikke noe ytelsesøkning uansett med g2 og 29.xx i forhold til eldre drivere.. prøv med orginaldriverene med nr 23.xx Lenke til kommentar
Cursed Skrevet 12. juni 2002 Forfatter Del Skrevet 12. juni 2002 høres lurt ut, men hvor får jeg tak i de? finner de ikke på sidene til nvidia Lenke til kommentar
Vidder Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Eneste feil er at du ikke har OpenGL installert. Dette følger ikke med windows-driverne, så last ned skikkelige drivere fra http://www.nvidia.com. Lenke til kommentar
Duke Soforth Skrevet 12. juni 2002 Del Skrevet 12. juni 2002 Har sett denne feilmeldingen på et par maskiner, i begge tilfellene var løsningen som følger: Åpne WIN.INI fila (ligger i windows-katalogen). Se om du finner en linje der det står følgende: DVA=0 Editer denne bort, f.eks slik: ; DVA=0 Restart så maskina og forsøk å starte spillet påny. Lenke til kommentar
Cursed Skrevet 13. juni 2002 Forfatter Del Skrevet 13. juni 2002 vidder: driverene jeg bruker nå har jeg lasta ned fra nvidia.com mortenj: jeg fant win.ini men det står ikke DVA=0 noen plass i den. Lenke til kommentar
