Bjørnar_88 Skrevet 12. januar 2005 Del Skrevet 12. januar 2005 Sitat fra www.omegadrivers.net Fast Gate A20 Option : ENABLED Video BIOS shadowing : DISABLED Video BIOS cacheable : DISABLED xxxxx - xxxxx Shadow : ALL DISABLED IDE prefetch mode : ENABLED Init Display First : AGP or PCI (SELECT YOUR CARD TYPE) IDE HDD Block Mode : ENABLED IDE 32-bit transfer mode : ENABLED Assign IRQ for USB : DISABLED (UNLESS YOU USE USB DEVICES) Assign IRQ for VGA : ENABLED PCI/VGA palette snoop : DISABLED PNP OS Installed : ENABLED (UNLESS YOU WANT TO MANUALLY ASSIGN IRQ's) Resource Controlled By : AUTO (UNLESS YOU WANT TO MANUALLY ASSIGN IRQs AND DMAs) AGP aperture size : 128 (USE 64MB IF YOU EXPERIENCE TEXTURE CORRUPTION) AGP master 1 WS write : DISABLED*** AGP master 1 WS read : DISABLED*** Bank 0/1, 2/3 DRAM timing : TURBO*** CPU to PCI write buffer : ENABLED Delayed Transaction : DISABLED**** DRAM speculative leadoff : ENABLED*** DRAM Data Integrity Mode : NON-ECC (UNLESS YOU HAVE ECC MEMORY) Delay DRAM read latch : (THE LOWER, THE FASTER)*** Fast writes : DISABLED Memory parity/ECC check : DISABLED*** Passive Release : ENABLED PCI Concurrency : ENABLED PCI master 0 WS write : ENABLED*** RAS active time : (THE LOWER, THE FASTER)*** RAS to CAS delay : (THE LOWER, THE FASTER)** Read around write : ENABLED SDRAM Bank Interleave : 4-bank/way SDRAM CAS Latency Time : 2** SDRAM cycle length : 2** SDRAM Precharge control : ENABLED Spread spectrum (modulation): DISABLED System BIOS cacheable : DISABLED Video RAM cacheable : DISABLED 8 bit I/O Recovery Time : 1 16 bit I/O Recovery Time : 1 Turbo frequency : ENABLED ** = ONLY IF YOUR MEMORY SUPPORT IT, OTHERWISE USE THE NEXT HIGHER VALUE *** = WILL IMPROVE SPEED BUT DECREASES STABILITY, IF YOU HAVE PROBLEMS, CHANGE IT **** = ENABLE IF YOU EXPERIENCE PROBLEMS WITH CREATIVE SOUND CARDS Hva skjer hvis jeg stiller på det merket med ** selv om RAMen min ikke støtter det? Jeg tror nemlig jeg har gjort akkurat det... Ihvertfall, når jeg slår på pc'n kommer det ikke noe bilde på skjermen. På displyet på HK står det bare FF. Lenke til kommentar
MorePower Skrevet 12. januar 2005 Del Skrevet 12. januar 2005 (endret) Clear cmos/resett bios. Kan gjøres ved å flytte en jumper på hk frem og tilbake mellom noen pinner. Eller ta ut batteriet på hk (det lille runde), la det være ute en liten stund, sett det i, og prøv og start maskina di igjen. Endret 12. januar 2005 av MorePower Lenke til kommentar
Bjørnar_88 Skrevet 12. januar 2005 Forfatter Del Skrevet 12. januar 2005 Jeg har prøvd jumperen uten resultat. Burde det funke bedre å ta ut batteriet? Lenke til kommentar
Bjørnar_88 Skrevet 13. januar 2005 Forfatter Del Skrevet 13. januar 2005 Å ta ut batteriet hjalp ikke. Lenke til kommentar
2rb Skrevet 13. januar 2005 Del Skrevet 13. januar 2005 Hvilket HK? Sjekk produsentens side. Du finner somregel manualen som PDF der... evt. FAQ. Lenke til kommentar
Bjørnar_88 Skrevet 16. januar 2005 Forfatter Del Skrevet 16. januar 2005 Det er et EPoX 8kra2+ HK. En 'dataekspert' prøvde å bytte ut alle deler i maskinen, men ingenting skjedde. Han mener at det er en feil enten på hovedkortet eller på BIOS'en. Lenke til kommentar
