Fogl Skrevet 12. januar 2005 Del Skrevet 12. januar 2005 Har et ASUS A8N SLI DELUXE og er ganske grønn på overklokking. kan noen derfor fortelle hva jeg må stille på gjerne med bilde for å få en 3200+ Lenke til kommentar
Spragleknas Skrevet 15. januar 2005 Del Skrevet 15. januar 2005 Noen tips her: Sitat When you get to 250, you need to set the HTT multi to 3x...Any FSB over 250 with a HTT multi of 4 gives you an HTT of over 1000Mhz....You need to keep the HTT frequency as close to 1000Mhz or less as possible. It is seperate from the CPU speed. To calculate HTT frequency: FSB x HTT multi = HTT frequency (should be 1000Mhz or less - some can go further) To calculate CPU frequency: FSB x CPU multi = CPU frequency (can be set to whatever despite HTT frequency) You can still lower the HTT frequency while OCing the CPU at the same time. You just need to change the HTT multi to correspond with the FSB speed you are running to maintain a HTT frequency of 1000Mhz or less. Lenke til kommentar
