Minne til T40?
obos
Hei
Jeg har en IBM T40 med 512 MB men jeg har lyst å oppdragere til 1024 MB, dvs, kjøpe meg en ny minnebrikke med 512 MB ekstra.
Hvilken type minne er best og som passer til T40? JEg er helt grønn på dette området og jeg takker og bukker hvis noen kan gi meg noen anbefalinger :)
  • 2 uker senere...
Greit jeg har lastet ned og kjørt programmet. Den sier at jeg kjører 2100.
så fant jeg denne type minnebrikke
Memory Corp 512MB DDR PC2100 Minne
266Mhz, 184pins
General Description of MC6464DDR32M88-266A
Memory Corp MC6464DDR32M88-266A series is unbuffered 184-pin double data rate Synchronous DRAM Dual In-Line Memory Modules(DIMMs) which are organized as 64Mx64 high-speed memory arrays. Memory Corp MC6464DDR32M88-266A Aseries consists of sixteen 32Mx8 DDR SDRAM in 333mil TSOP II packages on a 184pin glass-epoxy substrate. Memory Corp MC6464DDR32M88-266A series provide a high performance 8-byte interface in 5.25" width form factor of industry standard. It is suitable for easy interchange and addition.
Memory Corp MC6464DDR32M88-266A series is designed for high speed of up to 133MHz and offers fully synchronous operations referenced to both rising and falling edges of differential clock inputs. While all addresses and control inputs are latched on the rising edges of the clock, Data, Data strobes and Write data masks inputs are sampled on both rising and falling edges of it. The data paths are internally pipelined and 2-bit prefetched to achieve very high bandwidth. All input and output voltage levels are compatible with SSTL_2. High speed frequencies, programmable latencies and burst lengths allow variety of device operation in high performance memory system.
Memory Corp MC6464DDR32M88-266A series incorporates SPD(serial presence detect). Serial presence detect function is implemented via a serial 2,048-bit EEPROM. The first 128 bytes of serial PD data are programmed by Memory Corp to identify DIMM type, capacity and other informations of DIMM and the last 128 bytes are available to the customer.
Main features :
• 512MB (64M x 64) Unbuffered DDR DIMM based on 32Mx8 DDR SDRAM
• JEDEC Standard 184-pin dual in-line memory module (DIMM)
• 2.5V +/- 0.2V VDD and VDDQ Power supply
• 2.6V +/- 0.1V VDD and VDDQ Power supply for DDR266
• All inputs and outputs are compatible with SSTL_2 interface
• Fully differential clock operations (CK & /CK) with 125MHz / 133MHz
• All addresses and control inputs except Data, Data strobes and Data masks latched on the rising edges of the clock
• Data inputs on DQS centers when write (centered DQ)
• Data strobes synchronized with output data for read and input data for write
• Programmable CAS Latency 2 / 2.5 / 3 supported
• Programmable Burst Length 2 / 4 / 8 with both sequential and interleave mode
• tRAS Lock-out function supported
• Internal four bank operations with single pulsed RAS
• Auto refresh and self refresh supported
• 8192 refresh cycles / 64ms
så spm mitt er: hvordan ser man at den type minnebrikke er til bærbar? 184 pins? Den jeg har funnet... er den til bærbar? Vil ikke bestille feil :)
Du skal ha SO-DIMM DDR brikker som du f.eks finner her
Har du sjekket at du har DIMM slots ledig? Dvs om det fysisk er plass til flere ram moduler i maskinen?
jepp det er en plass til :)
når jeg kjørte den testen så nevnte den ingen ting om SO-DIMM eller noe... kun PC2100 DDR SDRAM.
Jeg beklager at jge er helt grønn når det gjelder pcer, men hva med den jeg har funnet over, er den til bærbar el til stasjonær?
Hvordan ser man at en minnebrikke er til bærbar el til en stasjonær?
Hva vil PC2100 si? Må jeg kjøpe nøyaktig samme el kan jeg også kjøpe en som har høyere tall (verdi) som f..eks. PC2700?
sorry men jeg har flere spm :)
fant denne linken på ibm sine hjemmesider
http://www-1.ibm.com/support/docview.wss?uid=psg1MIGR-41751
sjekket litt på komplett:
http://www.komplett.no/k/kl.asp?bn=10522
så spm mitt er:
(1) er minnebrikker PC2100 bedre enn PC2700? Eller det det ingen forskjell på dem? Grunnen til at jeg spør er at nettbutikker har begge på lageret.
All PC2700 memory is 333MHz Double Data Rate (DDR)
All PC2100 memory is 266MHz Double Data Rate (DDR)
If the memory modules are mixed (for example, using both PC 2100 and PC 2700) or the system supports only PC2100 memory, then the system memory will run at 266MHz.
så forskjellen er hastigheten men siden systemet mitt kjører kun 266MHz så spiller det ingen rolle for meg. Right?
(2) er det noen forskjell på SODIMM og SODIMM (DDR)? da jeg kjørte Everest test så sto det SDRAM DDR. Så jeg tipper at jeg må kjøpe SO-DIMM DDR...
Stemmer det at jeg må kjøpe en minnebrikke som er f.eks. SO-DIMM (DDR) PC2700?
TwinMOS 512MB SO-DIMM DDR PC2700 333Mhz
non ECC - 32Mx8 / 16 chips, CL2,5 619,-
er litt småredd å bestille feil type.... :)
Endret av obos
Forskjellen er hastigheten brikkene er spesifisert for. Du har allerede svaret på dette.
Det spiller mao ingen rolle om du velger 2100 eller 2700 siden brikkene uansett vil kjøre på 2100 hastighet
SO-DIMM er SDRAM, dvs den typen som var vanlig før DDR kom på markedet. Disse kommer i PC100 og PC133, så disse skal du ikke ha.
SO-DIMM DDR er den typen du skal ha :thumbup:
