Hvor skal denne ledningen?
thomba14
SATA diskene lyser på dette lyset ja.
Ikke 100% sikker på dette:
Tror ikke IDE og P-ATA er det samme. Slik jeg har forstått er S-ATA og en form for IDE.
Although the standard has always had the official name "ATA", marketing dictates dubbed an early version of the standard Integrated Drive Electronics (IDE), and the one following it Enhanced IDE (EIDE). Although these new names originated in branding convention and not as an official standard, the terms EIDE or E-IDE often appear interchangeably with IDE and ATA. With the introduction of Serial ATA around 2003, this configuration retroactively became renamed as Parallel ATA (P-ATA), referring to the method in which data travels over wires in this interface.
Edit: La på om IDE
Endret av Explorer
HDD  = Harddisk
IDE = P-ATA harddisk (?)
Det betyr vel at S-ATA ikkje vil gje lys i denne dioden?
Fant noen forklaringer på IDE, for de interesserte.
Google er min venn :)
IDE: "Integrated Drive Electrnics" er det vanligste grensesnittet på vanlige hjemmePC'er idag. En standard IDE-kontroller har uttak til fire enheter, for eksempel harddisk, CD-ROM, ZIP-drive osv.
IDE (Integrated Drive Electronics--or numerous other interpretations) and ATA (AT Attachment) are one and the same thing: a disk drive implementation designed to integrate the controller onto the drive itself, thereby reducing interface costs, and making firmware implementations easier. This low cost/easy integration created a boom in the disk drive industry, as PC integrators readily ate up the low-cost alternative. Since the late 80's, ATA (as it is properly called) has become the drive of choice for the cost inhibited buyer.
thef-nym.sci.kun.nl
Explorer hadde kommet med litt ekstra også ja :thumbup:
Endret av am3k
