Jedde Knekt To
Open Sesame
First, look around the hangar. On the left and right side of the ship, next to the walls, are two breakable floor grates. One is very obvious, the other is covered by a crate. Take the one with the crate first. Use Force Push to move it, and then break the grate and crawl down. At the end of the passageway, look up and you'll see another grate above your head. Break through and jump up to kill the enemies in this room. There are five switches here; hit them all, and Lando radios you to say one of the doors has opened. Crawl back out through the passageway and into the hangar, then run across to the other side. Break the floor grate by the red fuel tanks, climb through and you'll get to a room exactly like the one before. Kill the guys and hit the five switches to open the other roof door. Climb back through the passageway and go out into the hangar again.
Hentet fra http://www.epigamer.com/article.php?a=76
Fra samme guide:
Searching for the Control Center
Go out into the room, kill the Gran then follow Lando to the lift. At the top, keep following him until you get to the window overlooking his ship. He'll stay there, and will tell Kyle to find the flight control center and open the hangar roof doors. Go back down the corridor and take the lift to the room you first entered. The door on your right will be open. Go through the hallway and out into the room with the big pit. Kill the few enemies here and continue onward. You'll have to use your light goggles to get through this room. The exit leads you outside, where you'll be spending most of your time. Head over to the walkway far ahead of you, on the left. Snipe the Rodian, and then proceed down the walkway, taking the door at the end, on your right. Clear out the next room and continue around the corridor until you reach a door at the end, across from a window. Sneak a look up out the window; there is a Rodian waiting to zap you. Go through the door and out on to a new walkway. Kill the Gran in front of you and then look up to the left at the turrets shooting you. Take them out and then jump up to them. There are a number of guys in this room. Grab the two health canisters and continue through the left hallway. This will lead you to a juncture with a door in front, to the left, and to the right. Go straight, kill the Rodian and hit the button. Lando radios in to say he now has access to the starpad. Head out of the room, and with your back facing the corridor you came from, take the door on the right. Go down the ramp and check out the large building in front of you, on the other walkway (the one with the two large pipes leading into it). This is the hangar. Move around the walkways, following the hangar perimeter all the way around until you can go in the big entrance. You'll meet up with Lando, and then fend off a large attack. Lando tells you to hold them off while he tries to start the ship. Once they're all dead, join Lando inside the ship and he'll give you two objectives; fix the fuel lines to the ship, and find the controls for the roof doors.
