Mørbradbiff Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 (endret) Hei, jeg trenger hjelp til routeroppsett for å koble xbox opp til xbconect eller xlink. Jeg har en "TopCom: Sky@cer WBR 244" router Jeg er desperat, takker for all hjelp! Endret 7. januar 2005 av DjKs Lenke til kommentar
Sir_cruz Skrevet 8. januar 2005 Del Skrevet 8. januar 2005 Do I need to forward any ports? You'd be happy to know that nearly all routers will no longer require any port-forwarding for use with XLink Kai. Upon connection, each user is probed for a randomly open port and assigned that port should a connection to the Orbital be successful. However, there will always be a select few people who will have no alternative but to force a port-forward. If Kai reports your network as unreachable, port-forward port 30000 on UDP to the local IP of the PC running Kai. Remember to enter the port number in 'Kai Port' in the Kai Configuration Tool. Leave Kai Deep Port as 0!. If you are behind a network that will not allow you to forward ports, but are allocated a few ports (generally on College campuses for gaming), use whatever port number you have available, as long as it is a UDP port-forward (see also: 2.2 How will I know if I need to port-forward?)... Note: If you are a user of other tunnelling programs, such as XBConnect, you can use the 8602 UDP port-forward already designated (just remember to enter it in the Kai Configuration Tool under 'Kai Port'). ------------------------------------------------------------------------------------------------ How will I know if I need to port-forward? If you've been following the Quick Start Guide then you would have been checking to see if Network Reachable reports as 'Yes'. If it says 'Not yet', then you know you've got to port-forward. Alternatively, if people tell you that your ping always shows 'Establishing', you'll need to port-forward ----------------------------------------------------------------------------------------------- How do I configure my software firewall to play with XLink Kai? With so many different software firewalls available, each product will require different configuration. Firewalls can be responsible for not allowing you to view available games to join as well as kicking you from a game as soon as you join. Do no port-forward port 3074 UDP - these are software firewall instructions. As a general rule of thumb, try the following: • For XBox users, allow the IP address 0.0.0.1 full access on UDP. • Also for XBox users, allow port 3074 full access. • If you are still experiencing problems, browse our Official XLink Forums. Note: Highly unrecommended but you Lenke til kommentar
