Naruto Anime - Spoileradvarsel!
jepp, ser ut som det kommer et par fillers frem over:
quotet fra Narutofan.com.
s the Naruto anime series is only one episode away from being extremely close to the arc the current Naruto manga series is on, what we all knew will happen, is happening. In the month of June we will see the second set of Naruto filler stories come to life as Naruto heads to Rice Field Country on a Super-S Class mission. Apart from all the complaining you will hear from people you have to recognize that this is a good thing for the series, regardless what the storyline is like. It is much better then Naruto going off air for months, losing its audience and being cancelled, after the anime caught up with the manga. We definately wouldn't want that to happen, so this could very well be a blessing.
Upcoming episode titles: Episode 135: The Promise That I Could Not Keep. Episode 136: Infiltration Investigation!? The Super-S Class Mission Which Has Finally Come! Episode 137: Town of Outlaws. Shadow of the Fuumaa Group. Episode 138: The Promise Betrayed, The Fleeting Request. - it is unclear how long this arc will last, however one could speculate they will try and stretch it out to let the manga series progress farther.
blir spennende å se hvordan dette "super-s" oppdraget blir.
kanskje blir det bare naruto, sakura og kakashi som drar? eller får de inn en stand-inn for sasuke? :p
hadde vært sinnsykt rått gaara hadde blitt med dem hehe, men det er nok bare ønsketenkning.
:wallbash:
Bra det ikke blir en pause i hele skiten da :>
Enig. Sikkert mange manga-fans som er uenige, men
fillers > total pause
:yes:
Faktisk så er det mange manga-fans som blir glade for å få en anime-del som de ikke vet hvordan ender fra før... Hehe... Alt spørs jo på kvaliteten til denne spin-off'en selfølgelig... Håper de har funnet på noe litt mindre teit enn den løpe greia og "lightsaberen".
Heller dette enn pause.
Jeg har hørt mange snakke om Naruto og hvor bra det er osv. så derfor tenkte jeg at jeg også hadde lyst til å følge litt med.
Men det jeg lurer på er om det er for sent å hoppe inn i serien akkurat nå?
neida, siden det er en "nedlastbar serie" kan du jo laste ned alle som hittil har vært (dvs 135 episoder) og starte på nr 1, det var det jeg gjorde for et par måneder sida... tar litt tid og ta igjen serien, men etter en måned eller no har du sikkert sett alle ;)
