TV-ut i linux
fglrx støttar TV-ut heilt ok. Kjem snart ny drivar som sagt, du kan sikkert vente på den.
TV ut fungerer den, men det er ikke akkurat noe nVidia kvalitet men, men.....
Får håpe for alle som bruker ATI at driverene som kommer er noe bra. Ikke for å være noe buzz kill men tror dere virkelig at de blir noe bedre?
Jeg har også ati 9600. Tv ut funker så det suser her. Er mobile jeg har, men tipper det ikke har så mye å si... :roll:
Sender med xorg.conf, så du kan teste. Tipper du må endre en del ting som f.eks synaptic driverne.
#    Xfree86Config
#***********************************************************************Some nice extensions
# DRI Section
Section "dri"
   Mode 0666
EndSection
# Module section
Section "Module"
   Load        "dbe"        	# Double buffer extension
   Load "synaptics"
   SubSection  "extmod"
   EndSubSection
   Load        "type1"
   Load        "freetype"
   Load        "glx"        	# libglx.a
   Load        "dri"        	# libdri.a
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
   RgbPath	"/usr/X11R6/lib/X11/rgb"
   FontPath   "/usr/X11R6/lib/X11/fonts/local/"
   FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
   FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
   FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
   FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
   FontPath   "/usr/X11R6/lib/X11/fonts/Speedo/"
   FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
   FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
# Server flags section.
Section "ServerFlags"
#    Option "DontZap"        	# Disables ctrl-alt-backspace.
#    Option "Dont Zoom"      	# Disables ctrl-alt +-.
#    Option "DisableVidModeExtension"    	# Disables tuning with the xvidtune client.
#    Option "AllowNonLocalXvidtune"    	# Uncomment this to enable the use of a non-local xvidtune client.
#    Option "DisableModInDev"      # Uncomment this to disable dynamically modify mouse - keyboard.
#    Option "AllowNonLocalModInDev"    	# Uncomment to change mouse keyboard whit non-local client.
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
   Identifier	"Keyboard1"
   Driver	"Keyboard"
   Option "AutoRepeat" "500 30"
   Option "XkbRules"	"xfree86"
   Option "XkbModel"	"pc102"
   Option "XkbLayout"	"no"
EndSection
# Core Pointer's InputDevice section
# USB - Mouse
 Driver       "mouse"
 Identifier   "Mouse1"
 Option       "ButtonNumber" "6"
 Option       "Device" "/dev/input/mice"
 Option       "InputFashion" "Mouse"
 Option       "Name" "AutoDetected"
 Option       "Protocol" "ImPS/2"
 Option       "Vendor" "AutoDetected"
 Option       "ZAxisMapping" "4 5"
 EndSection
# MousePad - Synaptics drivers
       Identifier      "Mouse2"
       Driver          "synaptics"
       Option          "Device"                "/dev/event/event1"
       Option          "Protocol"              "auto-dev"
       Option          "LeftEdge"              "1900"
       Option          "RightEdge"             "5400"
       Option          "TopEdge"               "1900"
       Option          "BottomEdge"            "4000"
       Option          "FingerLow"             "25"
       Option          "FingerHigh"            "30"
       Option          "MaxTapTime"            "180"
       Option          "MaxTapMove"            "220"
       Option          "VertScrollDelta"       "100"
       Option          "MinSpeed"              "0.08"
       Option          "MaxSpeed"              "0.18"
       Option          "AccelFactor"           "0.00018"
       Option          "UpDownScrolling"       "on"
       Option          "SHMConfig"             "on"
Option "SendCoreEvents"
EndSection
# Monitor section
Section "Monitor"
   Identifier  "Monitor0"
   HorizSync   31.5 - 91.1
   VertRefresh 60 - 100
   Option "DPMS"
EndSection
Section "Monitor"
   Identifier  "Monitor1"
   HorizSync   30-50
   VertRefresh 60
   Option "DPMS"
EndSection
# Graphics device section
#Section "Device"
#    Identifier  "Standard VGA"
#    VendorName  "Unknown"
#    BoardName   "Unknown"
#    Driver      "vga"
#EndSection
# ATI
Section "Device"
   Identifier                          "ATI0"
   Driver                              "fglrx"
   #Option                              "NoDDC"  	# Disable php monitor
   Option "no_accel"                   "no"    # Disable / Enable XAA/DRI
   Option "no_dri"                     "no"    # Disable / Enable XAAY/DRI
   Option "DesktopSetup"               "0x00000000"
   Option "MonitorLayout"              "AUTO, STV"
   Option "IgnoreEDID"                 "off"
   Option "HSync2"                     "30-50"
   Option "VRefresh2"                  "60"
   Option "ScreenOverlap"              "0"
   Option "NoTV"                       "no"
   Option "TVStandard"                 "PAL-B"
   Option "VideoOverlay"               "on"
   Option "OpenGLOverlay"              "off"
   Option "UseFastTLS"                 "0"
   Option "BlockSignalsOnLock"         "on"
   Option "UseInternalAGPGART"         "no"
   Option "ForceGenericCPU"            "no"
   BusID "PCI:1:0:0"          # vendor=1002, device=4e50
   Screen 0
EndSection
Section "Device"
  Identifier "ATI1"
  Driver "fglrx"
  Option "TVHPosAdj" "8"
  BusID "PCI:1:0:0"
  Screen 1
EndSection
# Screen sections
Section "Screen"
   Identifier  "Screen0"
   Device      "ATI0"
   Monitor     "Monitor0"
   DefaultDepth 24
   Subsection "Display"
       Depth       24
       Modes       "1400x1050" "1280x1024" "1024x768" "800x600" "640x480"
       ViewPort    0 0
   EndSubsection
EndSection
Section "Screen"
   Identifier  "Screen1"
   Device      "ATI1"
   Monitor     "Monitor1"
   DefaultDepth 24
       Depth       24
       Modes       "800x600"
       ViewPort    0 0  # initial origin if mode is smaller than desktop
#        Virtual     1280 1024
   EndSubsection
EndSection
# ServerLayout sections.
Section "ServerLayout"
   Identifier  "Server Layout"
   Screen "Screen0"
   Screen "Screen1" Below "Screen0"
   InputDevice "Mouse1" "CorePointer"
   InputDevice "Mouse2"
   InputDevice "Keyboard1" "CoreKeyboard"
   Option "OffTime" "20"
EndSection
