Spragleknas Skrevet 5. januar 2005 Del Skrevet 5. januar 2005 Of our top four boards, we can honestly say that any of these 4 would be a great choice. The K8N Neo2 and Gigabyte K8NSNXP are both based on the nForce3 Ultra chipset, and the Abit AV8 and Asus A8V Deluxe Revision 2 are very clearly the top of the VIA boards, reaching our second best overclocks at 289 and 280. However, if you look carefully at the features, performance results, and just plain class in a market segment filled with top performers, the MSI K8N Neo2 stands out. Based on top performance, the full implementation of the nForce3 Ultra features, value, overclocking performance, and flexibility, the MSI K8N Neo2 Platinum emerges from a class of top Socket 939 Athlon 64 boards as our Gold Editors Choice. This makes the K8N Neo2 our choice as the best Athlon 64 motherboard that you can buy. Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3439919
Erik_s Skrevet 5. januar 2005 Del Skrevet 5. januar 2005 En ting jeg vil si.. kjøp nForce. ikke Via osv . er som regel mye ustabilere. Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3439984
Lord Hell Skrevet 5. januar 2005 Del Skrevet 5. januar 2005 Abit Av8 k8t800 pro har jo Wake on lan funksjon (noe som jeg savner hos Nforce3 kort) jeg kommer nok til å gå får Abit Av8 Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3440002
C4STOR Skrevet 5. januar 2005 Del Skrevet 5. januar 2005 Of our top four boards, we can honestly say that any of these 4 would be a great choice. The K8N Neo2 and Gigabyte K8NSNXP are both based on the nForce3 Ultra chipset, and the Abit AV8 and Asus A8V Deluxe Revision 2 are very clearly the top of the VIA boards, reaching our second best overclocks at 289 and 280. However, if you look carefully at the features, performance results, and just plain class in a market segment filled with top performers, the MSI K8N Neo2 stands out. Based on top performance, the full implementation of the nForce3 Ultra features, value, overclocking performance, and flexibility, the MSI K8N Neo2 Platinum emerges from a class of top Socket 939 Athlon 64 boards as our Gold Editors Choice. This makes the K8N Neo2 our choice as the best Athlon 64 motherboard that you can buy. Motherboard:Abit AV8 The nForce3 250Gb/Ultra may be our favorite chipset of 2004, but our favorite motherboard is actually Abit's K8T800 Pro-based AV8. The board's chipset isn't the most feature-rich on the block, but the AV8 has what matters, namely excellent application performance, Serial ATA RAID support, and a working AGP/PCI lock for overclocking. What makes the AV8 really special is all the little things that Abit did with the board, though. uGuru is probably the AV8's biggest merit. Abit has always been known for its excellent motherboard BIOSes, and uGuru is a natural extension of that. Not only does uGuru offer an unprecedented level of overclocking, tweaking, monitoring, and fan speed control options in the BIOS, it also brings many of those capabilities to Windows. For an enthusiast, it's hard to go wrong with a motherboard that boasts adjustable temperature-controlled fan speeds for all on-board headers; hardware monitoring that's extensive enough to cover fan speeds, temperatures, and voltages; and a working AGP/PCI lock that opens the door to all sorts of overclocking potential. In addition to uGuru, the AV8 also packs digital audio input and output ports, high-end Rubycon capacitors throughout, and a budget sub-$110 street price. That's the complete package for an enthusiast's motherboard. Det finnes ingen fasit, kun meninger. I likhet med vanlig folk så har hardware sider sine egne meninger om hva de liker og de kårer vinnere deretter. Tingen er at vi som skal kjøpe hardware kan lese om det og gjøre oss opp våre egen mening om hva vi vil ha. Litt synd at så mange kjøper det andre forteller dem er best, istedet for at de gjør seg opp en mening om hva de selv vil ha. K8T800Pro har f.eks havnet helt i skyggen av nForce3. Det er ikke det at nForce3 er så mye bedre, det er heller det faktum at folk tror at den eventuele forskjellen som er spiller en rolle. Derfor spør man gjerne "Hva er best.." og folk svarer gladelig utifra hva de synes. Det hele blir egentlig som å si at Thomas Wassberg var best på 15km langrenn i OL i 1980 når han slo Juha Mieto med et hundredels sekund Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3440095
PreZiDenT Skrevet 6. januar 2005 Del Skrevet 6. januar 2005 Det må jeg faktisk legge til var et høydepunkt i langrennshistorien, C4STOR. Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3440689
Spragleknas Skrevet 6. januar 2005 Del Skrevet 6. januar 2005 µGuru-programvaren som fulgte med kunne ikke gå høyere enn 300 MHz, så det ble et naturlig stoppested for overklokkingen. Denne frekvensen var ikke helt stabil, og vi fikk VPU-feil i Windows. Det betyr i korte trekk at skjermkortet slutter å fungere slik som det skal. Vi tok dermed kontakt med ABIT for å høre om dette kunne ha noe med en halvfungerende AGP-lås. Vi fikk etter kort tid tilbakemelding om at de støtte på det samme problemet ved samme frekvens, og at det derfor måtte anses som det naturlige ustabilitetspunkt for kortet. Litt overrasket var vi derfor da vi noen dager senere mottok en "OC Guide" fra ABIT der de skrøt av å ha kommet helt opp til 336 MHz. Vi måtte gå ned noen steg før vi kunne anse systemet som stabilt, og vil nok ikke anbefale å kjøre systemet på noe særlig mer enn 290 MHz HTT-frekvens hvis man har ønske om høy stabilitet - med mindre det har kommet en ny revisjon av kortet, noe som det kan tyde på at det har gjort. ABIT fortalte oss nemlig at kortene som skulle leveres på markedet kom til å gå rett til revisjon 1.1. Litt typisk Abit med mange rev.'er? Bl.a. nF2 korta og K8T800pro til s754. mener nF3 kortet mitt har WOL Abit har uGURU ... msi har CoreCell som er ok... Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3442055
Lord Hell Skrevet 6. januar 2005 Del Skrevet 6. januar 2005 mener nF3 kortet mitt har WOL hvilket kort har du ? Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3442856
omr Skrevet 6. januar 2005 Del Skrevet 6. januar 2005 Blander meg litt inn her, men er i basis ute etter et 939 kort og er godt fornøyd med tidligere Nvidia. Skal settes sammen med AMD 64 3500 Winchester og Corsair Twinx 2*512. Forslag? Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3442952
Spragleknas Skrevet 6. januar 2005 Del Skrevet 6. januar 2005 MSI K8N neo2 Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3443224
hrrr Skrevet 6. januar 2005 Forfatter Del Skrevet 6. januar 2005 ok takker for alle svar og spesielt de med erfaringer av andre socket 939 hovedkort. jeg har nå i kabinettet mitt (Mercury) 2x120MM + 3x80MM stillegående mvh hrrr Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3443872
Lord Hell Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 jeg har denne her og Point of view 6800Gt og tenker jeg skal kjøpe meg Abit Av8 k8t800pro. med amd 64 xp3500+ Winchester versjon. gleder meg. tør ikke ennå pga jeg holder på med bil lappen, har 19000 men skal ha lappen først Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3449005
.Marcus Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 gjett hvem som sitter her med et GB K8NS-Ultra og ikke kan innstallere det før han får metallbakplaten fra microplex for å feste en XP-120 og klokke en 3000+ til den driter elektroniske duppeditter? Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3451185
Lord Hell Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 hehe nice står mellom det og Abit av8. må finne ut om det har wake on lan Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3451348
uberboss Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 En ting jeg vil si.. kjøp nForce. ikke Via osv . er som regel mye ustabilere. Det kommer vel litt ann på all den andre hardwaren du har stappa inn??Jeg har akkurat motsatt erfaring....ALLE Via kort jeg har hatt har vært dønn stabile,mens de 2 nforce korta (NF7S-v2.0) har det vært problemer med fra dag 1....kjøp det du mener passer best til deg,ikke hva andre sier du skal kjøpe,til syvende og sist er det DU som skal bruke maskinen,ikke sant?? Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3451870
.Marcus Skrevet 7. januar 2005 Del Skrevet 7. januar 2005 (endret) hehe nice står mellom det og Abit av8. må finne ut om det har wake on lan noen ideer om hvor det står på pakken så kunne jeg sjekket for deg. har duallan, en gblan utgang og en mblan. dualbios er med, dualchannel er selvsagt også med. blit mye dual nå i dataverdenen, eneste det mangler er at det skulle vært dualcpu men gi meg en pm eller no' slikt om hvilken rubrikk det står i, for å bruke språket som kalles n00b EDIT: dette fant jeg på produktsiden til kortet: Chipset NVIDIA nForce3 Ultra Platform Processor Super I/O: ITE IT8712F chip Integrated peripherials Silicon Image sil3512 controller T.I. IEEE1394b controller Marvell 8001 Gigabit Ethernet controller ICS 1883 LAN PHY chip Realtek ALC850 Audio AC'97 Codec Står litt om Ethernet kontrolleren og lan-chipen ihvertfall Endret 7. januar 2005 av Hubman Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3452440
Spragleknas Skrevet 8. januar 2005 Del Skrevet 8. januar 2005 hehe nice står mellom det og Abit av8. må finne ut om det har wake on lan her msi neo2 plat det har wol mener jeg bestemt! leste det i hk boka nettopp Lenke til kommentar https://www.diskusjon.no/topic/355807-beste-hovedkort-s939/page/2/#findComment-3456032
