500GB HDD fra Hitachi
Hitachi annonserer 500GB disk
Deskstar 7K500 – The Hitachi 7K500 offers 500 GB, the industry's largest available capacity for high-end media center PCs, DVRs, nearline storage and other enterprise ATA applications. The SATA version of the drive ships with a large 16 MB buffer to deliver breakthrough performance for bandwidth-intensive applications. In addition to the complete set of SATA II features, the drive includes Rotational Vibration Safeguard (RVS), a technology used to ensure drive performance in high rotational vibration environments, where there are multiple drives in a single enclosure.
Deskstar 7K500
500 GB (GB = 1 billion bytes, accessible capacity may be less)
817 Mb/s max. media data rate
8.5 ms average seek time
7,200 RPM, 4.17 ms average latency
ATA-100/Serial ATA 3.0 Gb/s
Smooth Stream Technology
25.4 mm in height
76 billion bits per square inch maximum areal density
5 aluminum platters
10 GMR recording heads
225 G (2ms) non-operating shock
9.0 watt idle power (Parallel ATA)
9.6 watt idle power (Serial ATA)
3.1 Bels typical idle acoustics
Fluid Dynamic Bearing (FDB) spindle motor
Og den kommer selvsagt med NCQ. Eneste spørsmålet fra meg nå er støynivået. :)
:thumbup:
Endret av Nostradamus
  • 2 måneder senere...
SATA II bussen er på 3Gb/s, som kan overføre 300MB/s med data..
... i teorien.
Hitachi har visst begynnt å oppgi reelle transfer-hastigheter:
Sustained data rate (MB/sec): 64.8 - 31 (zone 0 - 29)
Noen nye linker om denne harddisken:
http://www.hitachigst.com/hdd/support/7k500/7k500.htm
http://www.hitachigst.com/portal/site/en/?...b937c27aac4f0a0
http://www.itavisen.no/showArticle.php?articleId=1305821
