Kan jeg overklokke en 1,9GHz P4?
Number of CPUs 1
Name Intel Pentium 4
Code Name Willamette
Specification Intel® Pentium® 4 CPU 1.90GHz
Family / Model / Stepping F 1 2
Extended Family / Model 0 0
Brand ID 8
Package PGA-423
Core Stepping D0
Technology 0.18 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 1893.8 MHz
Clock multiplier x 19.0
Front Side Bus Frequency 99.7 MHz
Bus Speed 398.7 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 256 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 1893.8 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard manufacturer DFI
Motherboard model WT70EC,
BIOS vendor Award Software International, Inc.
BIOS revision 6.00 PG
BIOS release date 09/07/2001
Chipset Intel i850 rev. A3
Southbridge Intel 82801BA (ICH2) rev. 4
Sensor chip Winbond W83627HF
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type RDRAM
DRAM Size 1024 MBytes
DRAM Frequency 398.7 MHz
FSB:DRAM 1:1
Total CAS# (tRDRAM) 11 clocks
Row To Column (tRCD) 7 clocks
# of memory modules 5
Module 0 Kingston RDRAM PC1066 - 256 MBytes
Module 1 Samsung RDRAM PC1066 - 256 MBytes
Module 2 Samsung RDRAM PC1066 - 256 MBytes
Module 3 Kingston RDRAM PC1066 - 256 MBytes
Module 4 DDR2-SDRAM
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
eller andre forslag til å bedre maskinen min ?
Har du hovedkort som lar deg overklokke går det fint an å overklokke den prosessoren.
tror jeg har et DFI WT70EC om det sier noen noe?
hva gjør jeg for å overklokke, og hvor mye tror du jeg kan klokke CPU'en til ?
har lest på overklokking.no men ble ikke klokere, fant bare ut hva det var, ikke hvordan jeg gjør det :no:
Endret av ernie_g
