Hvordan lage elementere .gif filer ?
Har nå brukt dette : Ulead GIF Animator 5 TBYB
Men hvordan kan jeg få en mer glidenede overgang mellom bildene, eller eventuelt en annen effekt som for.eks gjør at bildene glir i hverandre like mens det skiftes bildet eller noe...
Det krever flere bilder. Noen programmer har en sånn funksjon, andre ikke.
Hvordan i alle verdens land og dager kan du forsvare bruk av MNG fremfor GIF når verken Gecko eller Safari støtter dette filformatet?
Helst fordi w3c anbefaler det fremfor GIF, fordi MNG har vært under arbeid siden 1996 og siden det allerede har blitt brukt, blant annet av U.S. Army, for å sitere rett, og det har vist seg å være meget bra.
Because the images making up a MNG are in PNG format, MNG shares the good features of PNG:
  • It is unencumbered by patents.
  • It is streamable.
  • It has excellent, lossless compression.
  • It stores up to 16 bits per channel.
  • It provides transparency and an alpha channel.
  • It provides platform-independent rendition of colors by inclusion of gamma and chromaticity information.
  • It provides early detection of common file transmission errors and robust detection of file corruption.
  • Single-image GIF (Graphical Interchange Format) files can be losslessly converted to PNG.
In addition, MNG has the following features:
  • It provides animation with loops and variable interframe delays.
  • It allows composition of frames containing multiple images.
  • It facilitates the use of images as "sprites."
  • It capitalizes on frame-to-frame similarities to reduce the amount of data that must be included in the datastream.
  • It provides "restart" points at which an animation can be resumed in case of data loss or corruption.
  • A "frame priority" chunk allows authors to indicate which frame should be displayed by single-image viewers and a subset of frames that should be displayed by slow viewers.
  • Multiple image GIF files can be losslessly converted to MNG.
