Den store ASUS A8N SLI tråden
MrAHB
                              Model : A8N-SLI DELUXE
    DOS Flash utility: Awdflash.exe for ASUS V1.09
    BIOS Location: ftp://ftp3.asus.com.tw/rddata/MB/BIOS/A8N-SLI DELUXE
Phoenix Award Utility: ftp://ftp3.asus.com.tw/rddata/MB/BIOS/TOOLS/Phoenix Award
BIOS version: 1003    Date:01/20/2005
Checksum: C700H
1. Modify A8N-SLI DELUXE BIOS version to 1003.
BIOS version: 1003-010    Date:01/19/2005
Checksum: EE00H
1. Modify HT safe value from 5X to 4X to fix somtimes K8 sempron CPU fails to boot
2. Modify CPU Vcore for 1.40V (Low Power CPU) for MR
3. Hide 'CPU Voltage' Item options from 1.55V~1.65V when using 1.40V CPU, because the low power CPU doesn't support upper 1.55V
4. Modify Linear Overclock formula to fit H/W request
5. Add a SETUP Item to control the CPU fan fail message threshold RPM
BIOS version: 1003-009    Date:01/17/2005
Checksum: 5200H
1. Re-translation item strings, value and help to French.
2. Don't porting GPO5 to fit H/W request
BIOS version: 1003-008    Date:01/13/2005
Checksum: CD00H
1. Fixed asus update 64bit OS fail
2. Change the SLI mode setting from 'SLI' to 'auto' when user switch to Dual card mode by SLI windows utility
3. Fixed CPU voltage will pull high in the begining of POST and then pull down after memory sizing
4. Do one more time PCI_reset to fix fail to boot from bootblock after support DualGPU card
BIOS version: 1003-007    Date:01/11/2005
Checksum: 5E00H
1. DMI information : Fixed AMD Athlon64 CPU's Processor Family will be wrong shown as 'Opteron'
2. Add DMI type08 information : 'CPU Fan','Power Fan','Chassis Fan * 2','Chipset Fan'
3. Fixed when CPU multiplier select 4X or 4.5X and HT set to 5X , system will hang on 29h , it is because the HT speed cannot be faster than CPU speed (AMD Spec)
4. Fixed AMD Sempron can not boot up because wrong HT setting.
5. Fixed DDR CL value will be wrong after resuming from S3 (only MR PCB)
6. Support nVidia DualGPU PCIE VGA card.
7. Rewrite EZ-plug checking code to support both Normal/QuickSwitch PCB
BIOS version: 1003-006    Date:01/06/2005
Checksum: 3D00H
1. Correct Hyper Transport item string for multi-language..
2. Support Setting SLI/Normal mode by windows utility
3. Change CopyRight year from 2004 to 2005
4. Modify AMD K8 939 3800+ PST table to fix failing to enter OS when enable cool'n'Quiet , the solution is change the lowest VID from 1.1V to 1.2V
BIOS version: 1003-005    Date:12/30/2004
1.Fixed PCI Clock locked on 33MHz (PLL to CPU) fails to work
BIOS version: 1003-004    Date:12/22/2004
1.Change VID Max Value from Vcore_Default+100mv to 1.65V
BIOS version: 1003-003    Date:12/15/2004
1.support PEG for ATI X850 PCIE card
2.Modify DDR speed :in Class A, when 4 DIMMs pluged , DDR400 will down to DDR333
3.Set DDR timing reg TRP,TRCD min value to 3
BIOS version: 1003-002    Date:12/09/2004
Checksum: 3C00H
1.Fixed when overclock over 220MHz , HT doesn't down to 3X
2.Change MR table D , overclock over 240MHz , DDR200==>DDR266
BIOS version: 1003-001    Date:12/03/2004
1. Modify Cool 'n' Quiet string and default value
Her kan du se alle "fixene" som er gjort i 1003.
Har selv en 3500+ og kommer ikke over 1,584V.
Jeg begynner å lure på om denne CPUen ikke støtter høyere spenning?
Se nr 3 i bios 1003.010 :hmm:
Eg har flasha te den biosen JimRamse la ut. Såkalt beta versjon. Ka bør eg bruka, den siste offisielle eller den beta versjonen ?
CPU'en ska vel klara 1.65V, har jo sett folk som har hatt 1.75V ( dette er jo litt for høgt ) så eg trodde ikkje 1.65V skulle skapa noe problemer.
Irreterande, føler at CPU har mer å gi, men at den trenger litt mer "juice" (for de som ikkje skjønne det; les: volt :thumbup: )
JimRamse linket vel til en annen beta versjon 1006 eller noe ? Funker kanskje bedre med denne biosen, noen som har den biosen installert som kan si noe om den ?
Vil bare si at eg hadde detta problemet med spenning på CPU med orginal bios også!
Endret av Furyfax
Hmm sitter med et problem:
Har:
OCZ PC3700EB Plat Edition
AMD64 3500+
A8N-SLI Deluxe kortet
Får kjørt minnet og FSB stabilt opp til 245 men etter det = ustabilt og mye styr.. hjelper ikke og gi minnet slappere timeings heller (tom. prøvd 2T timeings..)
Noen som har en løsning? ;)
prøvd å øke volten på cpu og minnet?
Edit: du er jo en del over det minnet er spesifisert for...hvor slappe timings har du prøvd?
2T, 2.5-4-4-9 (og 11)
Uten noe hell, kjører 3.0volt på minne, 1.65volt på CPU
Rammen er utrolig god overclockings ram, så burde ikke være noe problem,
Kjører RAM/FSB 1:1 på 245mhz med standar timeings ( 1T, 2-3-3-8) nå og det er stabilt.. Har hørt om at over 245FSB blir A8N-SLI korta ustabile? Men ser jo folk som kjører 300FSB stabilt ;)
Edit:
Kjører 11x245mhz
Endret av Snabben
hmm....det er ikke disse brikkene du har?
i så fall brukere du strammere timings enn det de er spesifisert for...
jeg har verken hørt eller erfart at disse kortene blir ustabile over 245!
edit: fjernet noe tull! ;)
Hei:)
Bruker disse brikkene her:
http://netshop.no/aspx/prdinfo.aspx?plid=4558
Jeg kan jo prøve noen andre timeings, noen forslag til hva jeg burde prøve på? :))
Prøvde 3-4-4-8 (2T) timeings, tom 3-4-4-11 (2T) uten lykke, ikke engang på 260mhz.. hmm, varme er heller ikke noe problem, har vannkjøling på systemet :)
Det ville jo vært usansynlig dårlig om CPUen ikke clocker mer enn 2.64ghz stabilt med vannkjøling og bra ram :)
tja...nå er vel 2.6 det de fleste winchester-cpu'er kommer til...jeg la ikke merke til at det var en 3500+ du hadde...da er det ikke såå rart at den sier stopp rundt 245...
Skal komme lengre med den er jeg ganske sikker på, har sett winchester på så høyt om 3.2ghz :)
Og 2.9ghz for en AMD64 3000+ "Winnie"
2.6ghz er luftkjøling clock, hehe
Edit:
http://www.home.no/jimramse/Pictures/325x9_1-1.JPG
JimRamse har vært heldig f.eks. ;)
Endret av Snabben
Har lastet ned bios, er ei .bin fil.
Samtidig har jeg lastet ned AWDFLASH108.
Hvordan går jeg videre nå, kopierte begge over på disket, sliter må
å få boota opp i dos får å flashe.
Har jo alltid fått dette til før :cry:
Er det bare meg som ikke skjønner noen ting :blush:
Jeg har da http://netshop.no/aspx/prdinfo.aspx?plid=2273 og jeg kjører min 3200 synkront med minnet, på 266(533) @ 2.5-4-4-7 uten noen problemer (2.66ghz) da kjører minne standard timings og clock så jeg tror jeg har en del og gå på, jeg boota på 2.7 uten problem, har egentlig ikke testa så mye mer rett og slett pga det er så kjedlig å resete cmos hele tia.. :p
Jeg prøvde og gå rett på 2.8 men det var lite populært, da mangla det visst noen filer i windows osv !
En i klassa nevnte at man bør klokke gradvis oppover, at man rett og slett kunne klokke lengre etter at systemet hadde "kjørt seg in" litt, kan jo bare være tull men er jo lov å håpe!
Jeg for min del er fornøyd med 2.66
Edit : har dual channel mye å si hvis noe i det hele tatt på hvor langt man kan klokke ? har bare en brikke atm, men har en til som blir shippa på mandag..
Endret av gsn
Rammen er utrolig god overclockings ram, så burde ikke være noe problem.
Hvilken spenning står det i CPU-Z at prosessoren får?
En ting er den spenningen du setter i bios enn annen ting er hva hovedkortet faktisk gir prosessoren.
