Xzibiter Skrevet 28. desember 2004 Del Skrevet 28. desember 2004 HELP i finaly got my motherboard working and my graphic card working... now when i try to start computor it seems to recognize everything but when the xp startup screen should appear it restarts instead... plz help me Lenke til kommentar https://www.diskusjon.no/topic/351185-restarting-plz-help/
PsychoPat Skrevet 28. desember 2004 Del Skrevet 28. desember 2004 You got you motherboard and graphics card to work... So what was the matter with them? Or are you trying to explain that you have installed it, and it works? If you machine won't boot, why don't you try to reinstall Windows? Lenke til kommentar https://www.diskusjon.no/topic/351185-restarting-plz-help/#findComment-3384483
PsychoPat Skrevet 28. desember 2004 Del Skrevet 28. desember 2004 (endret) You should refer to your last post, where you asked for help with your motherboard and graphics card. Here is the link: http://forum.hardware.no/index.php?showtopic=351003&hl= Edit: Your topic stinks in this thread as well as in your previous post! Endret 28. desember 2004 av PsychoPat Lenke til kommentar https://www.diskusjon.no/topic/351185-restarting-plz-help/#findComment-3384505
Flakkmeister Skrevet 28. desember 2004 Del Skrevet 28. desember 2004 did you uninstall the old drivers before you installed the new cards? If not, try insert the old cards and uninstall the drivers. anyway, when you have installed a new motherboard, its always a good thing to format your operative system partition, or else the system can be unstable, like for example your`e problem. Lenke til kommentar https://www.diskusjon.no/topic/351185-restarting-plz-help/#findComment-3384522
