Tips til dere om et godt program
Patience
Ville bare tipse dere om dette programmet..
Bruker det på serveren for å monitorere oppetiden. Men det godt for så mye mer..
Fra snapfiles.com:
Link: http://www.snapfiles.com/get/coolinfo.html
CoolMon is a small system monitoring application that displays current system data and performance statistics on your desktop. What s cool about it is that it does not have an interface of it s own, it rather displays the data in a simple text format right on your desktop, blending in with your wallpaper or background without taking up any additional desktop space. You can customize the information to be displayed and (on Windows 2000/XP) adjust the transparency of the display as well. Most of the application s data is retrieved from the Windows 2000/XP performance counters, so while CoolMon will work on Win9x, it will display much less information than on a Win2K machine, which it is primarily intended for. CoolMon can also be configured as a server and a client allowing you to monitor remote machines on the network.
Endret av Patience
