hvordan fjerne Hijack!
jeg for ingen servere opp på cs, det skjedde helt plutselig så jeg reinstalerte xp med det hjalp ikke, så fant jeg dette på www.steampowered.com men jeg skjønte ikke helt hva jeg skal gjøre.
jeg tror jeg har hijack på nettverket eller noe sånt fordi jeg husker jeg lasta ned en mappe fra dc++ med hijack er ikke sikker.
men vis jeg har jickack blir det borte etter å reinstalere xp?
jeg har ikke instalrt noen brannmur enda, bruker egentlig NIS04 (med lisens)
men her står fasiten av problemet mitt
er det noen som kan hjelpe meg litt? skjønte ikke så mye av dette
husk at det er jul og greier :xmas:
There are a few things that can cause this.
Probably the #1 cause is you are running one or more firewalls. You should only be running one firewall and you can't just "disable" one, you must remove all references to steam.exe, hl.exe and hl2.exe before you disable them. Some firewalls like ZoneAlarm do not work well under XP SP2, you should uninstall ZA and just use the XP2 firewall if you have connection problems.
The next biggest possible cause is that you are running "Deterministic Network Enhancer" which is used with Cisco and a few other VPN applications. Other VPN programs have other network hooking methods that can cause internet connection problems. Uninstall all VPN programs if you are having connection problems.
The #3 biggest problem is you have X-Fire or Google Remote Desktop or one of a few other applications that hijack your network connection. There are number of spyware programs that do this too. If you installed Ultimate Arena, that also installs a hijack for your network connection and can cause network problems. Uninstall it.
Here are some general guidelines on how to figure out what is causing it.
The first question is has this just started after a Steam update or has it been happening for a while?
Steam Just Updated - it's your Firewall
If it just started after a Steam update, then chances are very good that your Firewall is blocking Steam.
To fix this, remove Steam.exe and all instances of HL.exe from the firewall permissions and re-add them or let the firewall re-discover them when you run the game. Be sure to give permission for all ports and for TCP and UPD for Steam.exe and for every hl.exe that pops up (it will ask permission for each different game you run).
You might see the symptom where you can see servers from the Steam ServerBrowser but not from the in-game ServerBrowser (at the splash screen). This means that your firewall is blocking hl.exe but not Steam.exe.
If it's the other way around, IE: you can't see Servers in Steam but you can while in-game, then your firewall is blocking Steam.exe. There may be other symptoms if Steam.exe is blocked (friends won't work, etc).
No Steam Update
If this just started out of the blue, you should go check over at the Steampowered forums and see if other players are having this problem. If this is happening to a number of players then the Steam Network might be having problems. Certainly if you are unable to get to the Steam Forum that would also indicate that this is a Steam Network problem.
If no one else is having this problem and you have your firewall properly configured, then you might have a routing problem with your ISP, or some network connection between you and the Master Servers. If the problem persists more then a day then you might need to call your ISP.
Additional Firewall Information
Certainly, if you just installed a new firewall or updated your firewall software then you need to make sure you configure it before you start looking for outside problems. Some anti-Virus programs have a built-in firewall too, so be sure to check there.
The latest XP SP2 update has a more aggressive firewall, so if this just started happening after you did a Windows update then you will need to look at the SP2 firewall for this problem.
:xmas:
nei si det du skulle si
jeg tror det er noe med at nettverket ikke tilater , eller stengt port eller noe sånt
det står hva jeg skal gjøre lengre oppe men jeg skjønte det ikke helt
det har ikke noe med brannmur å gjøre isåfall
Endret av banantiss
