Viva Skrevet 5. juni 2002 Rapporter Del Skrevet 5. juni 2002 Warning: Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug in /home/forum/www/auth.php on line 97 Warning: MySQL Connection Failed: Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug in /home/forum/www/auth.php on line 97 An Error Occured -------------------------------------------------------------------------------- phpBB was unable to connect to the database. Please check $dbhost, $dbuser, and $dbpasswd in config.php.Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug Lenke til kommentar
Kjetil Lura Skrevet 5. juni 2002 Rapporter Del Skrevet 5. juni 2002 den fikk eg og nettopp,hva er galt. Kjetil Lenke til kommentar
