Hva betyr "J'n" på noen Intel prosessorer?
Intel Ships Processors with Enhanced Security Capabilities
Intel Corp., the world's leading maker of microprocessors, chipsets and network
components, Monday said it had been shipping central processing units with
security capability called XD-bit for some time, while a number of retailers
began to supply the chips to end-users. áAll the [microprocessor] parts with the
á-Jö designator have XD bit and have been shipping for several weeks now,ö an
Intel's spokesman told X-bit labs. Execute Disable bit a security feature that
protects certain system memory data regions from insertion and execution of
potentially harmful code, that is also referred as NX-bit and works only in
conjunction with Windows XP operating systems that feature Service Pack 2.
Execute Disable bit allows the processor to classify areas in memory by where
application code can execute and where it cannot. When a malicious worm attempts
to insert code in the buffer, the processor disables code execution, preventing
damage or worm propagation. To provide end-to-end no execute (NX) coverage,
Intel already released XD-enabled chips for workstations, and other server
products beginning in late Q3 2004. Desktop products are now shipping, with
system availability in Q4 2004. Mobile processors will begin shipping in late Q4
2004, with system availability in Q1 2005. áWe did not make any official
announcement on the XD bit enabled processors,ö another Intel representative
said. Akiba PC Hotline web-site reports that the first batch of Intel Celeron D
340J, 335J, 330J and 325J has made it to the retail. End-users should get the
revamped chips at approximately the same or slightly higher cost compared to
versions without XD bit. Intel said only Intel Celeron D chips in LGA775
packaging support XD bit technology, furthermore, BIOS and operating system of
the system should support the tech to enable it. Advanced Micro Devices, another
leading maker of microprocessors, has been shipping AMD Opteron and AMD Athlon
64 central processing units with no execute bit (NX-bit) support since April and
September, 2003, respectively. Intel first introduced its XD-enabled processor ó
the Itanium ó in 2001.
Puuuh,langt innlegg,orket ikke redigere......
