Oppkobling av XBOX mot projektor X1?
malcolm
Jeg har kjøpt xbox som julegave til dama, hehe, som jeg skal koble opp mot min projektor og lerret. Noen som kan være så vennlig å forklare meg hvordan jeg kan gjøre det, eller vet om en link eller noe hvor dette blir forklart?
Jeg har en Infocus X1, philips dvd 963SA og en philips FR996 forsterker.
Google er din venn.
Edit: Min også. Se hva jeg fant her:
I have the HD output kit for the X-Box. I can't get it to show anything either through the component into special S Video adapter that came with the pj (with the X-Box set for 480p, 720p or 1080i output), nor will it work when I put the component outputs of the X-Box through a component to VGA adapter and run it into the computer input.
The s-video adapter should work when the XBox is in its setup menu (no disc in the drawer) which is 480i. In the setup menu you will need to tell the XBox that your TV is HDTV compatible. Once setup this way, connecting the component output to the VESA connector via a simple RCA to 15-pin adapter should get it to work properly in 480p or higher. Be advised that there are very, very few titles that will "turn on" the HDTV modes in the Xbox. A couple of popular ones are Dragon's Lair (1080i) and Enter the Matrix (720p or 1080i).
Tip: the green output from the HD pack will give a black and white image if plugged into the composite input. This will let you view the dashboard without swapping A/V packs.
It was quite easy to set up the xbox for those who were coming across problems. After attaching the HD pack to the xbox, I hooked up the green cable to my tv to see a black and white image. The settings for widescreen, 420p, 720p, 1080i, Dolby Digital, and DTS were now all available in the settings menu. I enabled them all ( i left the projector in 4:3 mode and let the xbox put out the widescreen format...worked best this way), used the breakout cable to hook up to the projector and voila. Note: To those that "upgraded" their xbox, all "extra features" are 480p so no need to worry about not being able to see menu's and such.
However if you have not "upgraded" your xbox, you simply just miss out on the beginning intro of the "X" splash screen. Once the game is initialized, the projector kicks in with the picture, so no real issues there unless for some reason you want to go back to the settings menu.
I tinkered with the projector's color temperature, RGB, and other settings a bit, but haven't really come up with anything that seems to be that much better. I used the progressive player for the xbox, and I honestly thought my cheap RCA DVD player with component out looked better. So those wishing to watch DVD movies with the projector will probably not be pleased. Also, its impossible to watch DVD's through the breakout cable from the xbox if it has not been "upgraded".
With a video game machine like the Xbox, running 480p will give you additional detail from your games that you won't get from 480i. This is because the Xbox and its games are natively a progressive source, so if you run 480p there is no deinterlacer involved at either end. On the other hand, if you run the Xbox at 480i it is actually having to downconvert the progressive source down to interlaced, and then the X1 has to deinterlace it back to progressive again. Some detail will get lost in the translation.
Håper dette hjalp, har ikke lest igjennom alt.
Endret av ehs5
Jeg kjenner ikke til din projektor og forsterker.
Dersom du bruker original kabel: Jeg antar at projektoren har en slik gul inngang for bilde (er det component den heter?). Bruk den. Ledningen fra xbox til tv består av tre plugger (rød, hvit (for lyd) og gul (for bilde)) som er plugget inn i en scart koontakt, slik at xboxen skal kunne brukes både med scart og component. For å koble til projektoren tar du bare av scart-kontakten. Mulig det høres komplisert ut, men det er umulig å ta feil når du ser kabelen og projektoren.
HDTV-kit som sitert om over, fungerer ikke med PAL. For å få det til å funke må du ha en xbox fra USA eller en moddet xbox. Jeg regner med at dette ikke er tilfellet for deg.
For å få surround lyd må du kjøpe en kabel til xboxen som støtter dette. Microsoft sin egen surround kabel heter noe slikt som Adcanced scart cable. Den har så vidt jeg husker bare scart ut, slik at du kan få problemer med projektoren. Personlig kjøpte jeg en slik kabel. Den har optisk ut og s-video signal for bilde som vel går til de fleste projektorer. Jeg tror at kabelen også selges av Expert-kjeden for ca 150. Jeg anbefaler å kjøpe den. Da får du optisk ut for surroundlyd, samt tilkoblinger for de fleste bildesignaler du kan kommer over.
Ok, hvis jeg forstår det rett nå så kan jeg gjøre som følger: Forlenge den gule kabelen(blir for kort sånn som den er) fra xboxen og kjøre den inn på projektoren, mens jeg kobler den hvite og røde kabelen inn på forsterkeren for å få lyden. Kommer dette til å fungere? Er det egentlig ikke lagt opp til å bruke xbox på projektor? Synes det er så forferdelig innviklet:(((
