Får ikke amarok til å fungere
Noen som vet hvorfor jeg ikke får amarok til å fungere (slack 10.0) ? Jeg får følgende utskrift etterfulgt av følgende popup et halvt minutt senere:
[amaroK loader] connecting to /home/bruker/.kde/socket-data/amarok.loader_socket
[amaroK loader] amaroK not running. Trying to start it..
kdecore (KIconLoader): WARNING: Icon directory /home/bruker/.kde/share/icons/Pastels-Nuvola-1/ group not valid.
amarok: BEGIN [static EngineBase* EngineController::loadEngine()]
amarok: [PluginManager] Plugin trader constraint: [X-KDE-amaroK-framework-version] == 3 and [X-KDE-amaroK-plugintype] == 'engine' and [X-KDE-amaroK-name] == 'void-engine' and [X-KDE-amaroK-rank] > 0
amarok: [PluginManager] Trying to load: libamarok_void-engine_plugin
amarok: [amaroK::Plugin::Plugin(bool)]
amarok:
amarok: PluginManager Service Info:
amarok: ---------------------------
amarok: name : <no engine>
amarok: library : libamarok_void-engine_plugin
amarok: desktopEntryPath : amarok_void-engine_plugin.desktop
amarok: X-KDE-amaroK-plugintype : engine
amarok: X-KDE-amaroK-name : void-engine
amarok: X-KDE-amaroK-authors : (Max Howell,Mark Kretschmann)
amarok: X-KDE-amaroK-rank : 1
amarok: X-KDE-amaroK-version : 1
amarok: X-KDE-amaroK-framework-version: 3
amarok:
amarok: END [static EngineBase* EngineController::loadEngine()]
amarok: [browserBar] Initialisation statistics:
amarok: Init: ContextBrowser
amarok: [ContextBrowser::ContextBrowser(const char*)]
amarok: [void ContextBrowser::setStyleSheet()]
amarok: Initial Color Properties: s:63 v:245
amarok: Unapplied Contrast: 97
amarok: Over-compensation: 87
amarok: Final Colour Properties: s:30 v:158
amarok: Time: 0.09s
amarok: Init: CollectionBrowser
amarok: [CollectionView::CollectionView(CollectionBrowser*)]
amarok: Collection dir removed: /dev/fd/23
amarok: Collection dir removed: /dev/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/rd
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/cpu
amarok: Collection dir removed: /dev/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/fd/23/cpu/0
osv, osv.... Hver eneste bidige fil på maskinen ramses opp
Endret av Hoppesagåsa
OK...slettet de mappene du nevnte p@rmann. Kom da et lite stykke på vei. Fant så ut at jeg måtte installere gst-plugins og gstreamer, da oppdatering fra sw9.1 til sw10.0 ikke har tatt hånd om det. Kjører forresten kde3.2 Nå får jeg følgende feil samt kræsj når jeg kjører "firsttime wizard" og scanner for mediafiler:
amarok: relocation error: amarok: undefined symbol: _ZN13KListViewItem10insertItemEP13QListViewItem
Satte xine som engine. Nå kan jeg i det minste dra-og-slippe ei fil inn i spillelista og spille den av. Men jeg får fremdeles samme feilmelding når jeg skal scanne. Denne funksjonen er tross alt en av hovedgrunnene til at jeg vil bruke amarok.
Jeg har teste både pakke fra linuxpackages.net , og jeg har prøvd å kompilere selv, uten synlige forskjeller.
Takk for usedvanlige kjappe svar forresten!
Her er meldingene jeg får når jeg prøver å scanne ei enkelt mappe med mp3'er:
amarok: [void CollectionView::scan()]
amarok: [void CollectionDB::scan(const QStringList&, bool, bool)]
amarok: BEGIN [void App::applySettings(bool)]
amarok: Discovered 196 widgets in PlaylistWindow
amarok: END [void App::applySettings(bool)]
amarok: [weaver] Started..
amarok: BEGIN [void CollectionReader::readTags(const QStringList&, std::ofstream&)]
amarok: [void CollectionDB::createTables(bool)]
amarok: [void CollectionDB::dropTables(bool)]
amarok: ERROR: [bool CollectionDB::execSql(const QString&, QStringList*, QStringList*, bool)] [CollectionDB] sqlite3_compile error:
amarok: ERROR: table directories already exists
amarok: ERROR: on query: CREATE TABLE directories (dir VARCHAR(100) UNIQUE,changedate INTEGER );
amarok: END [void CollectionReader::readTags(const QStringList&, std::ofstream&)]
amarok: [virtual void CollectionDB::customEvent(QCustomEvent*)]
amarok: [void CollectionView::renderView()]
amarok: [weaver] Done!
Eh, om du har kompilert og installert programmet, skal det legge set i PATH.
find / -name amarok
BTW: Om KDE ikkje ligg i /usr, men i /opt, må du velge det i ./configure. Mange distroar legg no KDE i /opt etter KDE-utviklarane sine ønske.
./configure --prefix=/opt/kde
Om KDE ligg i /opt/kde.
