p2p får ruteren til å streike
Jeg har et problem med ruteren som har gitt meg grå hår en stund. Ruteren er en 3com 3C857 og jeg har Telenor ADSL. ADSL modemet er fra Lucent. Jeg er ganske sikker på at dette er problemet mitt som jeg fant på 3coms knowledgebase
OfficeConnect Gateway Family - Peer to Peer software locks up the gateway
Problem: Peer to Peer software locks up the Gateway or Router
Fact: OfficeConnect Gateway Family
Fact: OfficeConnect Secure Router
Fact: OfficeConnect VPN Firewall
Fact: OfficeConnect ADSL Wireless 11G Firewall router
Fact: Peer to Peer
Fact: Emule
Fact: Edonkey
Fact: Kazaa
Fact: File sharing
Cause: Peer to Peer software creates a queue of people connected to your machine, each connection uses a specific port assigned to it. Also does a queue of the people you are connected to assigning more ports to your connections.
If you have many connections in the queue, the firewall has to process and watch each of these connections.
For example a queue of 2000 is equal to 2000 web connections.
On a wireless connection this can cause the wireless network to become unstable.
Fix: Reduce the amount of allowed people in your queue, reduce the amount of files you have on your wish list to download.
Reducing this allows the firewall to free more memory for doing it's job and not get flooded with these requests, hence not loosing the access to the internet and needing to restart your 3Com device.
Also, make sure that the virtual memory on your Windows is set to let Windows handle it. Restricting the swap file size will cause memory restrictions that would cause disconnections too.
Har prøvd litt av forslagene til å fikse problemet men det blir ikke bedre. Dette skjer ca. 2 ganger pr. dag. Kutter jeg strømmen til ruteren og setter den på igjen fungerer alt som før etter et par minutter.
