Skal det være en brødrister?
3600,- for en brødrister! Det er det dummeste jeg har hørt! :blink:
"KitchenAid Pro Line 4-Slot Toaster & Accessories
Destined to become a kitchen classic, this toaster combines easy-to-use controls with the kind of advanced features enjoyed in professional kitchens. Choose from nine browning settings; an electronic heat sensor delivers consistent results slice after slice. A tone signals when toast is done, and bread remains in the warm toasting cavity until it is manually raised. Extra-long 1" wide slots accommodate bagels and specialty breads. Its die-cast aluminum and stainless-steel construction makes this a durable toaster you can hand down to the next generation. 15" x 10 3/4" x 8" high. A Williams-Sonoma exclusive. "
Hadde det gått ann å overklokke den, så hadde det sikkert blitt interessant
:p
V
