Få DX9-vanneffekter med DX8/8.1-kort (GF4 og opp)!
Før (thumbnail)
  Sitat
How to make an 'older' DX8.0/8.1 card look as good as DX9, with almost no performance hit?
The main distinction Half-Life 2 tries to make between DX9 and DX8.0/8.1 is that the water is much more reflective in DX9, apart from subtle differences in rest of the shaders. The following patch applies to all Geforce FX users, Geforce4 Ti users, Radeon 8x00, and 9000/9100/9200 users:
(Geforce3 not supported for some reason)
There is a patch now that enables the fancy water reflections on older hardware, even DX8.0 class Geforce4 Ti cards. I recommend this instead of the 3Danalyze trick if you are an FX user, since you can get 90% of the eyecandy of DX9 with 100% more performance.
Skal visst fungere på følgende kort
  • Geforce FX-serien
  • Geforce4 Ti-serien
  • Radeon 8x00-serien
  • 9000/9100/9200
- Half Life 2: Patch
- Counter Strike: Patch
Enjoy it! :cool:
Endret av guezz
