ruter standarer ?
Virke IEEE 802.11b på 802.11b?
IEEE 802.11b - often called Wi-Fi - is backward compatible with 802.11. The modulation used in 802.11 has historically been phase-shift keying (PSK). The modulation method selected for 802.11b is known as complementary code keying (CCK), which allows higher data speeds and is less susceptible to multipath-propagation interference.
The IEEE (Eye-triple-E) is a non-profit, technical professional association of more than 360,000 individual members in approximately 175 countries. The full name is the Institute of Electrical and Electronics Engineers, Inc., although the organization is most popularly known and referred
to by the letters I-E-E-E.
Kort sagt er det IEEE som har vært med på å utvikle standaren. Om det står IEEE 802.11b eller 802.11b er det samme.
