System helt mongo mulig virus?
Lurer litt på hva følgende prosesser er for noe:
  • winampa.exe (OK)
  • CLI.exe (OK)
  • WinBar.exe
  • MDM.exe (OK)
  • MBM5.exe
Kjenner du til disse programmene? :dontgetit:
Edit: Søkte litt på veven og fant ut at alle prosessene var legale, foruten MBM5.exe og WinBAr.exe. Hva disse gjør aner jeg fortsatt ikke.
Endret av Antikapitalist
  • winampa.exe (OK)
  • CLI.exe (OK)
  • WinBar.exe
  • MDM.exe (OK)
  • MBM5.exe
winbar er en ekstra linje som en kan ha mye rart som vist cpu, ram osv osv ;)
MBM5 = motherboardmonitor 5
  • winampa.exe (OK)
  • CLI.exe (OK)
  • WinBar.exe
  • MDM.exe (OK)
  • MBM5.exe
Akkurat som jeg sa. :cool:
Kan du forklare hva du mener med at maskinen oppfører seg rart?
Første skritt på veien: oppdater Internet Explorer.
Deretter gjør du følgende:
If you have the latest Internet Explorer version and all your Windows Updates, you can safely ignore the DSO Exploit as a potential problem when Spybot Search and Destroy or other spyware removal tools discover it. However if you would rather fix the exploit so it does not show up again, follow these steps to edit your Windows Registry. Please be careful however, incorrect changes to the Windows Registry can cause Windows to not boot.
  • Step 1: Make a note of the location of the exploit shown in Spybot, something similar to:
    HKEY_USERS\S-1-5-21-1614895754-73586283-725345543-500\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0\1004!=W=3
  • Step 2: Click on Start, Run, and type REGEDIT and Press Enter to open the Windows Registry Editor
  • Step 3: Find the location of the exploit above in the registry by clicking on the pluses(+) next to each title
  • Step 4: After opening the Zones section and clicking on '0' look to the right window, under 'name' is the key '1004' and the type is REG_SZ simply right click and delete this REG_SZ value.Then right click and create new>DWORD Value, name it 1004, then right click on that and goto modify, give it the Hex Value of 3, Click ok. If there is only a DWORD Value for the key (in this case 1004), then double click on the key and change the HEX value to 3 and click Ok.
  • Step 5: Close the Registry Editor and Reboot your computer
  • Step 6: The DSO Exploit should now be removed and it should no longer appear in the Spybot Search and Destroy log as a problem
Lykke til! :thumbup:
