PrayingMantis Skrevet 30. november 2004 Del Skrevet 30. november 2004 (endret) [color=red]Deler fra Komplett.no[/color] ---------------------- [url="http://komplett.no/k/ki.asp?sku=301942&cks=PRL"][b]NEC DVD recorder ND-3500A IDE Sort Bulk,DVD+R/+RW/DVD-R/-RW (Dual layer)[/b][/url] [color=red][b]= 595,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=301045&cks=PRL"][b]Intel Pentium 4 550 3.4 GHz Boxed Socket LGA775, 1MB cache[/b][/url] [color=red][b]= 2390,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=123996&s=sc"][b]Seagate Barracuda 7200.7 200GB S-ATA 8MB cache 7200RPM[/b][/url] [color=red][b]= 995,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=301604&cks=PRL"][b]Abit AA8-3rd Eye Hovedkort for S775 I925X,SATA,ATX,GbLAN,Dual-DDR2,PCI-Ex16[/b][/url] [color=red][b]= 1399,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=301600&s=sc"][b]Corsair Twin2X 5400PRO DDR2, 1024MB Kit w/two matched CM2X512-5400C4PRO[/b][/url] [color=red][b]= 2845,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=301228&view=detailed"][b]Sapphire Radeon X800XT PE 256MB GDDR3 PCI Express,Full-Retail[/b][/url] [color=red][b]= 4149,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=302888&cks=ACC"][b]Arctic Silver 5 Termisk Pasta 3.5 Gram[/b][/url] [color=red][b]= 69,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=114711&cks=PRL"][b]Sony Diskettstasjon 3,5" 1,44MB Sort Floppydisk Intern[/b][/url] [color=red][b]= 137,-[/b][/color] - [url="http://komplett.no/k/ki.asp?sku=304899&cks=PRL"][b]Razer Diamondback Chameleon 1600dpi, Optisk Mus, USB[/b][/url] [color=red][b]= 495,-[/b][/color] ---------------------- [color=red]Deler fra efast.no[/color] ---------------------- [url="http://www.efast.no/PartDetail.aspx?q=p:605982;r:pg"][b]BenQ FP937s[/b][/url] [color=red][b]= 3895,-[/b][/color] ---------------------- [color=red]Deler fra Mamoz.no[/color] ---------------------- [url="http://mamoz.no/produkt/70SB022200002/Creative_SB_Live!_Player.html"][b]Creative SB Live! Player 5.1 - Bulk[/b][/url] [color=red][b]= 248,-[/b][/color] ---------------------- [color=red]Deler fra microplex.no[/color] ---------------------- [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=PC6099B"][b]Lian Li PC 6099B[/b][/url] [color=red][b]= 1745,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=MISTMEGATWFAN"][b]MIST CPU-kjøler, Megatower, m/vifte[/b][/url] [color=red][b]= 495,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=LARKFLBB"][b]Floppykabel, 45cm, sort - rund[/b][/url] [color=red][b]= 49,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=MDSATA50CMVI"][b]S-ATA kabel, 50cm, vinklet[/b][/url] [color=red][b]= 59,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=LARK45BL"][b]ATA133 IDE-kabel, 45cm, blå[/b][/url] [color=red][b]= 75,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=RATPADZGS"][b]HardOCP musmatte, "RatpadzGS", Sort[/b][/url] [color=red][b]= 149,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=ARCOLVSATI4"][b]AC skjermkortkjøler, VGA Silencer ATI 4[/b] - ATI X800[/url] [color=red][b]= 249,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=CSK80BL"][b]Vantec Kabelstrømper, kit, blå[/b][/url] [color=red][b]= 99,-[/b][/color] - [url="http://www.microplex.no/rubweb/varer.asp?ARTNR=SWETBREGL1"][b]Windows Etch, "Break Glass"[/b][/url] [color=red][b]= 60,-[/b][/color] ---------------------- [color=red]Deler fra Netconnection.no[/color] ---------------------- [url="http://www.kontorplassen.no/website/templates/52/cart/product_info.asp?pid=503&SiteId=1161&LanguageId=119&MySessionID=521281892"][b]Tagan 480W Dual Fan/Active-PFC[/b][/url] [color=red][b]= 890,-[/b][/color] ------------------------ = [b]ca. 20900,-[/b] ------------------------ EDIT: Oppdatert litt av hvert... Endret 24. desember 2004 av gixxerman Lenke til kommentar
camxer Skrevet 30. november 2004 Del Skrevet 30. november 2004 Jeg ville bytte hk til denne. Er lit sjipt å spare på å kjøpe et HK med dårligere chipset... Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 Ok får vel tilføye litt info. Jeg SKAL ha Pentium(AMD er inget alternativ for meg). Hovedkortet skal være fra Asus. Sokkelen skal være nye 775 med PCI-express. Så spørsmålet får vel heller bli om det jeg har satt opp passer sammen, og hvilke av PSU'ene jeg burde velge. Sist men ikke minst så er budsjettet egentlig på maks 15000,- så jeg har allerede sprengt det litt. Lenke til kommentar
Andreasfe Skrevet 30. november 2004 Del Skrevet 30. november 2004 (endret) *glem det..* Så bra ut det der.. For å komme ned på budsjettet så kan du jo velge en annen DVD-brenner.. NEC 3500+ og Samsung et eller annet (Duell-testen fra i går). er jo rimelige og bra. Endret 30. november 2004 av Andreasfe Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 (endret) Har de 8x DVD brennehastighet da ? I tillegg valgte jeg den der da den har både hvitt og svart deksel. Skal ha svart kabinett så da vil jeg helst fullføre stilen EDIT: leste testen nå hehe, men begge har hvitt deksel. Mulig jeg er kravstor men når jeg først skal ha et stilrent kabinett i sort så bør alt det andre stå i stil, eller hur Endret 30. november 2004 av gixxerman Lenke til kommentar
Anonym1234567890 Skrevet 30. november 2004 Del Skrevet 30. november 2004 EDIT: leste testen nå hehe, men begge har hvitt deksel. Mulig jeg er kravstor men når jeg først skal ha et stilrent kabinett i sort så bør alt det andre stå i stil, eller hur Dersom du skal ha ein stilrein maskin må du innvistera i frontdeksel til Lian Li Lenke til kommentar
Andreasfe Skrevet 30. november 2004 Del Skrevet 30. november 2004 Har de 8x DVD brennehastighet da ? De har 16x brennehastighet Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 (endret) EDIT: leste testen nå hehe, men begge har hvitt deksel. Mulig jeg er kravstor men når jeg først skal ha et stilrent kabinett i sort så bør alt det andre stå i stil, eller hur Dersom du skal ha ein stilrein maskin må du innvistera i frontdeksel til Lian Li Weee, hadde jeg ikke tenkt på EDIT: Men på microplex.no har de jo ingen til NEC eller Samsung brennere. Hvordan vet jeg om de vil passe om jeg velger noen andre ? Endret 30. november 2004 av gixxerman Lenke til kommentar
GRendal Skrevet 30. november 2004 Del Skrevet 30. november 2004 Kjøp J CPUene.... 540J...bedre idle temp og bedre stepping.- Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 Er denne noe å satse på kontra den andre jeg har foreslått over ? I tillegg trenger jeg vel litt kjølepasta - Burde vel duge den ? Lenke til kommentar
ghost7 Skrevet 30. november 2004 Del Skrevet 30. november 2004 samsung og nec har begge svarte fornter også.. berre til info... Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 samsung og nec har begge svarte fornter også.. berre til info... Visst faen gjør den det, my bad Link Men da blir det den da Lenke til kommentar
2 Fast 4 Biltema Skrevet 30. november 2004 Del Skrevet 30. november 2004 Deler fra Komplett.no---------------------- Plextor DVD-brenner PX-716A IDE Retail inkl. sort og hvit front = 1195,- - Intel Pentium 4 540 3.2 GHz Boxed Socket LGA775, 1MB cache = 1890,- - Seagate Barracuda 7200.7 200GB S-ATA 8MB cache 7200RPM = 995,- - Asus P5GDC Pro Hovedkort for S775 I915P,SATA,ATX,GbLAN,DDR/DDR2,PCI-Ex16 = 1095,- - Corsair Twin2X 5400PRO DDR2, 1024MB Kit w/two matched CM2X512-5400C4PRO = 3090,- - Sapphire Radeon X800XT 256MB GDDR3 PCI Express,VGA/VIVO/DVI-I, Full-Retail = 3895,- ---------------------- Deler fra microplex.no ---------------------- Lian Li PC 6099B = 1745,- - MIST CPU-kjøler, Megatower, m/vifte = 495,- ---------------------- Her er et forslag til tre strømforsyninger som jeg ikke helt klarer å bestemme meg for enda - Forslag ? ---------------------- BQT P4 450W = 820,- - Chill Innovation CP-510A = 895,- - Tagan 480W Dual Fan/Active-PFC = 890,- ------------------------ = ca. 15300,- ------------------------ Da mangler det bare kabler men det har jeg ikke helt bestemt meg for enda. Forslag og tips mottas med takk Prisforskjellen mellom 3.2GHZ 3.4 e bare 500kr Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 500kr her og 500kr der. Uansett kan 3.2 klokkes opp om det måtte være ønskelig. Lenke til kommentar
PrayingMantis Skrevet 30. november 2004 Forfatter Del Skrevet 30. november 2004 Ok da har jeg oppgradert lista på toppen. Da bytta jeg til 3.4 fra 3.2 ghz CPU, og så bytta jeg til en billigere brenner. Så har jeg fått innspill fra andre angående PSU og har kommet frem til at Tagan PSU'en er best så da blir det den. Det jeg nå trenger hjelp til som jeg overhodet ikke har peil på er ledninger. Har hørt at runde kabler er en god innvestering så kom med forslag. Vil ikke ha sånne med leds men vanlige runde kabler som ikke lyser. Hvilke og hva og pris osv. kan dere foreslå til meg ? Hadde vært fint om dere fant frem på microplex.no da jeg skal kjøpe kabinett og cpu kjøler derfra. Lenke til kommentar
