Feil spennig på CPU?
osoerebo
Hei.
Jeg har en AMD 64 3500+ socket 939. Denne skal såvidt jeg har forstått operere på 2.2GHz, men Si Soft Sandra sier noe helt annet. I følge Si Soft så opererer den kun med 1.01GHz !!? Har jeg feil oppsett i BIOS eller noe slikt? For liten spenning på CPU kanskje?
Her er rapporten fra Si Soft:
SiSoftware Sandra
Processor
Model : AMD Athlon 64 Processor 3500+
Speed : 1.01GHz
Model Number : 3500 (estimated)
Performance Rating : PR1508 (estimated)
Type : Standard
Package : FC µPGA939
Multiplier : 5/1x
Minimum/Maximum Multiplier : 11/1x / 11/1x
Generation : G8
Name : MF Athlon 64 (K8 ClawHammer) 90nm ?GHz+ ?V
Revision/Stepping : F / 0 (10D)
Stepping Mask : DH7-CG
Core Voltage Rating : 1.100V
Min/Max Core Voltage : 1.100V / 1.550V
Maximum Physical / Virtual Addressing : 40-bit / 48-bit
Native Page Size : 4kB
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
Internal Instruction Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
L2 On-board Cache : 512kB ECC Synchronous Write-Back (16-way, 64 byte line size)
L2 Cache Multiplier : 1/1x (1005MHz)
Upgradeability
Socket/Slot : Socket 939
Upgrade Interface : Unknown
Supported Speed(s) : 3.00GHz+
Processor Power Management
Processor Throttling Enabled : Yes
Throttle Range : 45% - 100%
Environment Monitor 1
Model : Winbond W83627(T)HF ISA
Version : 9.00
Mainboard Specific Support : No
Sensors
CPU Temperature : 49.5°C / 121.1°F td
Auto Fan Speed Control : No
CPU Fan Speed : 4383rpm
CPU Voltage : 2.70V
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : Yes
DS - Debug Trace & EMON Store : No
ACPI - Software Clock Control : No
(W)MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SS - Self Snoop : No
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : No
PBE - Pending Break Enable : No
IA64 Technology : No
SSE3 Technology : No
MON - Monitor/MWait : No
DSCPL - CPL qualified Debug Store : No
EST - Enhanced SpeedStep Technology : No
TM2 - Thermal Monitor 2 : No
CID - Context ID : No
xTPR - Send Task Priority Messages : No
DAZ - Denormals Are Zero : Yes
Extended Features
SYCR - Extended Fast System Call : Yes
EMMX - Extended MMX Technology : Yes
FXSR - Instructions Optimisation : No
3DNow! Technology : Yes
Extended 3DNow! Technology : Yes
DEP/NX - No-execute Page Protection : Yes
AMD64/EM64T Technology : Yes
Power Management Features
STC - Software Thermal Control : No
TTP - Thermal Trip : Yes
VID - Voltage Control : Yes
FID - Frequency Control : Yes
TS - Thermal Sensor Built-in : Yes
Advanced Settings
System Ack Limit : 1 request(s)
System Victim Limit : 0 request(s)
Extended MTRR Types : Yes
I/O Type Range Registers : Yes
Top of Memory : 40000000 (1024MB)
Machine Check Architecture Settings
Number of Reporting Banks : 5 bank(s)
Exception Reporting Control Support : Yes
Variable Range MTRR Settings
MTRR 0 : 00000000-3FFFFFFF (0MB-1024MB) WB
MTRR 1 : F0000000-F7FFFFFF (3840MB-3968MB) WC
Variable Range IORR Settings
IORR 1 : F0000000-F7FFFFFF (3840MB-3968MB) rdMem wrMem
Fixed Range MTRR Settings
MTRR 0 Range 0 : 00000000-0000FFFF (0kB-64kB) WB rdIO wrIO
MTRR 0 Range 1 : 00010000-0001FFFF (64kB-128kB) WB rdIO wrIO
MTRR 0 Range 2 : 00020000-0002FFFF (128kB-192kB) WB rdIO wrIO
MTRR 0 Range 3 : 00030000-0003FFFF (192kB-256kB) WB rdIO wrIO
MTRR 0 Range 4 : 00040000-0004FFFF (256kB-320kB) WB rdIO wrIO
MTRR 0 Range 5 : 00050000-0005FFFF (320kB-384kB) WB rdIO wrIO
MTRR 0 Range 6 : 00060000-0006FFFF (384kB-448kB) WB rdIO wrIO
MTRR 0 Range 7 : 00070000-0007FFFF (448kB-512kB) WB rdIO wrIO
MTRR 1 Range 0 : 00080000-00083FFF (512kB-528kB) WB rdIO wrIO
MTRR 1 Range 1 : 00084000-00087FFF (528kB-544kB) WB rdIO wrIO
MTRR 1 Range 2 : 00088000-0008BFFF (544kB-560kB) WB rdIO wrIO
MTRR 1 Range 3 : 0008C000-0008FFFF (560kB-576kB) WB rdIO wrIO
MTRR 1 Range 4 : 00090000-00093FFF (576kB-592kB) WB rdIO wrIO
MTRR 1 Range 5 : 00094000-00097FFF (592kB-608kB) WB rdIO wrIO
MTRR 1 Range 6 : 00098000-0009BFFF (608kB-624kB) WB rdIO wrIO
MTRR 1 Range 7 : 0009C000-0009FFFF (624kB-640kB) WB rdIO wrIO
MTRR 2 Range 0 : 000A0000-000A3FFF (640kB-656kB) UC rdIO wrIO
MTRR 2 Range 1 : 000A4000-000A7FFF (656kB-672kB) UC rdIO wrIO
MTRR 2 Range 2 : 000A8000-000ABFFF (672kB-688kB) UC rdIO wrIO
MTRR 2 Range 3 : 000AC000-000AFFFF (688kB-704kB) UC rdIO wrIO
MTRR 2 Range 4 : 000B0000-000B3FFF (704kB-720kB) UC rdIO wrIO
MTRR 2 Range 5 : 000B4000-000B7FFF (720kB-736kB) UC rdIO wrIO
MTRR 2 Range 6 : 000B8000-000BBFFF (736kB-752kB) UC rdIO wrIO
MTRR 2 Range 7 : 000BC000-000BFFFF (752kB-768kB) UC rdIO wrIO
MTRR 3 Range 0 : 000C0000-000C0FFF (768kB-772kB) WP rdIO wrIO
MTRR 3 Range 1 : 000C1000-000C1FFF (772kB-776kB) WP rdIO wrIO
MTRR 3 Range 2 : 000C2000-000C2FFF (776kB-780kB) WP rdIO wrIO
MTRR 3 Range 3 : 000C3000-000C3FFF (780kB-784kB) WP rdIO wrIO
MTRR 3 Range 4 : 000C4000-000C4FFF (784kB-788kB) WP rdIO wrIO
MTRR 3 Range 5 : 000C5000-000C5FFF (788kB-792kB) WP rdIO wrIO
MTRR 3 Range 6 : 000C6000-000C6FFF (792kB-796kB) WP rdIO wrIO
MTRR 3 Range 7 : 000C7000-000C7FFF (796kB-800kB) WP rdIO wrIO
MTRR 4 Range 0 : 000C8000-000C8FFF (800kB-804kB) UC rdIO wrIO
MTRR 4 Range 1 : 000C9000-000C9FFF (804kB-808kB) UC rdIO wrIO
MTRR 4 Range 2 : 000CA000-000CAFFF (808kB-812kB) UC rdIO wrIO
MTRR 4 Range 3 : 000CB000-000CBFFF (812kB-816kB) UC rdIO wrIO
MTRR 4 Range 4 : 000CC000-000CCFFF (816kB-820kB) UC rdIO wrIO
MTRR 4 Range 5 : 000CD000-000CDFFF (820kB-824kB) UC rdIO wrIO
MTRR 4 Range 6 : 000CE000-000CEFFF (824kB-828kB) UC rdIO wrIO
MTRR 4 Range 7 : 000CF000-000CFFFF (828kB-832kB) UC rdIO wrIO
MTRR 5 Range 0 : 000D0000-000D0FFF (832kB-836kB) UC rdIO wrIO
MTRR 5 Range 1 : 000D1000-000D1FFF (836kB-840kB) UC rdIO wrIO
MTRR 5 Range 2 : 000D2000-000D2FFF (840kB-844kB) UC rdIO wrIO
MTRR 5 Range 3 : 000D3000-000D3FFF (844kB-848kB) UC rdIO wrIO
MTRR 5 Range 4 : 000D4000-000D4FFF (848kB-852kB) UC rdIO wrIO
MTRR 5 Range 5 : 000D5000-000D5FFF (852kB-856kB) UC rdIO wrIO
MTRR 5 Range 6 : 000D6000-000D6FFF (856kB-860kB) UC rdIO wrIO
MTRR 5 Range 7 : 000D7000-000D7FFF (860kB-864kB) UC rdIO wrIO
MTRR 6 Range 0 : 000D8000-000D8FFF (864kB-868kB) UC rdIO wrIO
MTRR 6 Range 1 : 000D9000-000D9FFF (868kB-872kB) UC rdIO wrIO
MTRR 6 Range 2 : 000DA000-000DAFFF (872kB-876kB) UC rdIO wrIO
MTRR 6 Range 3 : 000DB000-000DBFFF (876kB-880kB) UC rdIO wrIO
MTRR 6 Range 4 : 000DC000-000DCFFF (880kB-884kB) UC rdIO wrIO
MTRR 6 Range 5 : 000DD000-000DDFFF (884kB-888kB) UC rdIO wrIO
MTRR 6 Range 6 : 000DE000-000DEFFF (888kB-892kB) UC rdIO wrIO
MTRR 6 Range 7 : 000DF000-000DFFFF (892kB-896kB) UC rdIO wrIO
MTRR 7 Range 0 : 000E0000-000E0FFF (896kB-900kB) UC rdIO wrIO
MTRR 7 Range 1 : 000E1000-000E1FFF (900kB-904kB) UC rdIO wrIO
MTRR 7 Range 2 : 000E2000-000E2FFF (904kB-908kB) UC rdIO wrIO
MTRR 7 Range 3 : 000E3000-000E3FFF (908kB-912kB) UC rdIO wrIO
MTRR 7 Range 4 : 000E4000-000E4FFF (912kB-916kB) UC rdIO wrIO
MTRR 7 Range 5 : 000E5000-000E5FFF (916kB-920kB) UC rdIO wrIO
MTRR 7 Range 6 : 000E6000-000E6FFF (920kB-924kB) UC rdIO wrIO
MTRR 7 Range 7 : 000E7000-000E7FFF (924kB-928kB) UC rdIO wrIO
MTRR 8 Range 0 : 000E8000-000E8FFF (928kB-932kB) UC rdIO wrIO
MTRR 8 Range 1 : 000E9000-000E9FFF (932kB-936kB) UC rdIO wrIO
MTRR 8 Range 2 : 000EA000-000EAFFF (936kB-940kB) UC rdIO wrIO
MTRR 8 Range 3 : 000EB000-000EBFFF (940kB-944kB) UC rdIO wrIO
MTRR 8 Range 4 : 000EC000-000ECFFF (944kB-948kB) UC rdIO wrIO
MTRR 8 Range 5 : 000ED000-000EDFFF (948kB-952kB) UC rdIO wrIO
MTRR 8 Range 6 : 000EE000-000EEFFF (952kB-956kB) UC rdIO wrIO
MTRR 8 Range 7 : 000EF000-000EFFFF (956kB-960kB) UC rdIO wrIO
MTRR 9 Range 0 : 000F0000-000F0FFF (960kB-964kB) UC rdIO wrIO
MTRR 9 Range 1 : 000F1000-000F1FFF (964kB-968kB) UC rdIO wrIO
MTRR 9 Range 2 : 000F2000-000F2FFF (968kB-972kB) UC rdIO wrIO
MTRR 9 Range 3 : 000F3000-000F3FFF (972kB-976kB) UC rdIO wrIO
MTRR 9 Range 4 : 000F4000-000F4FFF (976kB-980kB) UC rdIO wrIO
MTRR 9 Range 5 : 000F5000-000F5FFF (980kB-984kB) UC rdIO wrIO
MTRR 9 Range 6 : 000F6000-000F6FFF (984kB-988kB) UC rdIO wrIO
MTRR 9 Range 7 : 000F7000-000F7FFF (988kB-992kB) UC rdIO wrIO
MTRR 10 Range 0 : 000F8000-000F8FFF (992kB-996kB) UC rdIO wrIO
MTRR 10 Range 1 : 000F9000-000F9FFF (996kB-1000kB) UC rdIO wrIO
MTRR 10 Range 2 : 000FA000-000FAFFF (1000kB-1004kB) UC rdIO wrIO
MTRR 10 Range 3 : 000FB000-000FBFFF (1004kB-1008kB) UC rdIO wrIO
MTRR 10 Range 4 : 000FC000-000FCFFF (1008kB-1012kB) UC rdIO wrIO
MTRR 10 Range 5 : 000FD000-000FDFFF (1012kB-1016kB) UC rdIO wrIO
MTRR 10 Range 6 : 000FE000-000FEFFF (1016kB-1020kB) UC rdIO wrIO
MTRR 10 Range 7 : 000FF000-000FFFFF (1020kB-1024kB) UC rdIO wrIO
PAT Settings
PAT 0 : WB
PAT 1 : WC
PAT 2 : UC-
PAT 3 : UC
PAT 4 : WB
PAT 5 : WC
PAT 6 : UC-
PAT 7 : UC
Performance Tips
Tip 210 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 236 : Vcore higher than rated maximum. Check Vcore setting!
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
