Hva er warez?
http://www.pcworld.no/dataleksikon :
"warez: pop. betegnelse på ulovlig, piratkopiert programvare."
http://whatis.techtarget.com :
"Warez (pronounced as though spelled "wares" or possibly by some pronounced like the city of "Juarez") is a term used by software "pirates" to describe software that has been stripped of its copy-protection and made available on the Internet for downloading. People who create warez sites sometimes call them "warez sitez" and use "z" in other pluralizations.
According to the International Planning & Research Corporation, warez Web sites cost software vendors $11.8 billion in 2001. The most popular downloads at warez sites include applications from major vendors such as Microsoft, Symantec, Macromedia, and Adobe Systems. The vendors have joined forces with the Business Software Alliance (BSA) to successfully close a loophole in Internet law that allowed warez distributors to avoid legal prosecution as long as they didn't profit monetarily from their distributions. (Use of warez software is also illegal and may result in a jail sentence.)
Warez should not be confused with shareware or freeware software applications, which are legal and may be freely copied and distributed."
Fks. om du kjøper en musikk cd for så å bruke et lite program som omgjør alle sangene på platen til mp3 format for så å uploade alle sangene til en webserver.
Så etter det viser du link på fks. ei webside slik at "folket" kan laste ned sangene ja så da har du enkelt å greit gitt ut "warez" :grin:
For å forkorte borre's svar litt:
Ware er en forkortelse av Software. Man legger til en z på slutten for å antyde at det er i flertall og at det er ulovlig distribuert. Samme gjelder for Appz(som i Applications), Gamez. Håper dette var en enkel og grei, men fullstendig forklaring
[ Denne Melding var redigert av: Baltazar på 2002-05-29 20:37 ]
