akarno Skrevet 25. november 2004 Del Skrevet 25. november 2004 (endret) Hei. Har en god del .jpg bilder fra et spill jeg vil sette sammen i en liten, veldig kjapp film. (Altså kjøre bildene veldig fort etter hverandre) Vet man kan bruke fraps o.l, men det var en "once in a lifetime" bug jeg bare måtte ha på film, og jeg hadde ikke fraps eller noe sånnt på da Noen som vet om et (gratis) program jeg kan bruke til dette? Edit: noen skrivefeil... Endret 25. november 2004 av Icluz Lenke til kommentar
spøkelse Skrevet 25. november 2004 Del Skrevet 25. november 2004 Hvorfor ikke lage en animert gif? Lenke til kommentar
Pingla Skrevet 26. november 2004 Del Skrevet 26. november 2004 Hvis du har WindowsXP bruk Moviemaker og eksporter til DV(PAL). En oppskrift her: MOVIE MAKER (Windows XP) Another method to assemble a series of images into a movie (e.g. lapse.wmv) is to use Movie Maker software that is included with Windows XP. Load Movie Maker, choose File - New - Project (if there are existing files in the collection area you may also need to choose File - New - Collection), next choose View - Options... and adjust Default imported photo duration (seconds): to 1 (even one can be a bit a long but this is the minimum available setting), choose File - Import..., open the required folder and select ALL of the time lapse photo files, click on Open, wait while the clips are created, then drag ALL the clips into the Timeline or Storyboard view. The Storyboard view is ideal for changing the position of a clip in the movie project. In the Timeline view you can adjust the play time of each clip - for fine adjustments use + (Zoom In) and drag the trim handles - this way the play time can be reduced to as short as 0.1 of a second. Use - (Zoom Out) to see more of the clips. Audio clips can only be added to the Timeline view. If you attach a microphone one option is Record Narration... - you can add your own voice overs. Another option is to Record from Audio CD. Title screens need to be created in another program, saved as a graphics file and then imported. As you assemble the movie use Play to review your progress. The final step is to save it in a file format suitable for your friends. Choose File - Save and select suitable settings. For more detailed information about how to use the software choose Help - Help topics - excellent content, index and search features are provided. Lenke til kommentar
