validation error på hjemmesiden min.
det er fordi div'ene er inni en <p>, hint når du prøver å validere er å velge "verbose results"
her er hva den sier om feilene:
The mentioned element is not allowed to appear in the context in which you've placed it; the other mentioned elements are the only ones that are both allowed there and can contain the element mentioned. This might mean that you need a containing element, or possibly that you've forgotten to close a previous element.
One possible cause for this message is that you have attempted to put a block-level element (such as "<p>" or "<table>") inside an inline element (such as "<a>", "<span>", or "<font>").
