NisseMannH4X Skrevet 24. november 2004 Del Skrevet 24. november 2004 (endret) Hei! Har laget meg en login, men jeg vet ikke om den er vanntett. Men tror det! Kan noen se om de finner passordet til siden i denne koden? Eller om noen kan komme seg utenom? My Webpage <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <title>anders-nico.com - Siden er under oppussing!! - Proud Sponsors of www.BYOL.tk</title> <link href="../styles/style.css" rel="stylesheet" type="text/css"> <script language="JavaScript"> <!-- function SymError() { return true; } window.onerror = SymError; var SymRealWinOpen = window.open; function SymWinOpen(url, name, attributes) { return (new Object()); } window.open = SymWinOpen; //--> </script> <script language="JavaScript" type="text/JavaScript"> <!-- function MM_goToURL() { //v3.0 var i, args=MM_goToURL.arguments; document.MM_returnValue = false; for (i=0; i<(args.length-1); i+=2) eval(args+".location='"+args[i+1]+"'"); } //--> </script> </head> <body> <b> <h2>Administrasjonsside for anders-nico.com </h2> </b> <form name='pass' method='post' action='?adm=login'> <input type='password' name='pass' class='inputfield'> <input type='submit' class='inputfield' value=' Login '> </form> <form action="" method="post" name="logout"> <input type="hidden" name="logout" value=""> <input type="submit" value=" Log out " class="inputfield"> </form> <input type="button" value="Tilbake til siden" class="inputfield" onClick="MM_goToURL('parent','../');return document.MM_returnValue"> </body> </html> <script language="JavaScript"> <!-- var SymRealOnLoad; var SymRealOnUnload; function SymOnUnload() { window.open = SymWinOpen; if(SymRealOnUnload != null) SymRealOnUnload(); } function SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymRealOnUnload = window.onunload; window.onunload = SymOnUnload; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </script> Endret 24. november 2004 av NisseMannH4X Lenke til kommentar
jorgis Skrevet 24. november 2004 Del Skrevet 24. november 2004 Hva har dette med PHP å gjøre? Jeg ser bare massevis av irrelevante javascript-snutter. Lenke til kommentar
Loomy Skrevet 24. november 2004 Del Skrevet 24. november 2004 Hvis det er en PHP-login du snakker om kan vi selvsagt ikke se det utifra den koden ..dessuten finner jeg ingen link til login av noe slag på "My Webpage" som du så elegant kaller den Lenke til kommentar
Goophy Skrevet 24. november 2004 Del Skrevet 24. november 2004 Eh... Det er ikke mulig å finne passordet utifra den kodesnutten..? Lenke til kommentar
Snorre123 Skrevet 24. november 2004 Del Skrevet 24. november 2004 Stor sjanse for at det ikke er trådstarters side, men kun en side han vil finne passordet til..? Lenke til kommentar
Goophy Skrevet 24. november 2004 Del Skrevet 24. november 2004 <title>anders-nico.com - Siden er under oppussing!! - Proud Sponsors of www.BYOL.tk</title> Ja, ser ut som om han vil inn og endre på noe hos www.byol.tk ... Lenke til kommentar
