Review av nVidia SLi på nettet!
HKS
Nå har flere sider kommet med review av nVidia sine SLi løsninger, både 6800 Ultra og GT testes i SLi oppsett, 6600GT også!
http://www.anandtech.com/video/showdoc.aspx?i=2284&p=1
From a performance standpoint, SLI is just about as good as it gets.  If you have the budget for it, a pair of GeForce 6800GTs will let you run at 1600 x 1200 with 2X or 4X AA enabled in the latest games while still maintaining a very smooth gaming experience – something that no single card is able to do.
http://graphics.tomshardware.com/graphic/20041123/index.html
It was to be expected: an SLI computer with GeForce 6800 Ultra or GT beats everything for performance! The performance reserves of an SLI system are tremendous. Even with an Athlon64 4000+ the cards almost always have to wait on the CPU. Only in a resolution of 1600x1200 pixels with 4x FSAA and 8x anisotropic filtering does an SLI system really have to work hard. These should be the preferred operational conditions for SLI. The game itself also has a large impact on the performance boost afforded by SLI. While shader-intensive games like Doom3 and Farcry benefit from SLI in lower resolutions, the performance improvement with older games like UT 2004 and Call of Duty turns out to be much less. Even Half-Life2 only gets limited benefit from SLI. At present a number of games will not run at all with SLI.
Ser ut som CPU'en begrenser nå... :D Får vel kaste ballen til AMD og Intel da! Ellers er det morro å se Tom's Hardware sine tester med et ATi X800XT PE og et 6800Ultra kort i samme system (med et SLi hovedkort... ATi og nVidia fungerer faktisk side om side :p )
Tror nok vi kommer til å se en papirlansering fra ATi ganske kjapt... De har pleid å vært raskest i høye oppløsninger med AF og AA, der eier nVidia dem med SLi nå, og spørr du meg, han som kaster ut penger etter et high-end kort for å få max med fps i spill, kaster også ut penger etter et SLi oppsett.
Vil også si noen ord som en informatiker, og programmerer. Det ligger en enorm jobb i driverene og logikken bak dette, jeg synes nvidia har gjort en god jobb der!
Blir spennende å se fremover, når flere SLi hovedkort kommer, flere grafikkort som støtter det, samt nye driver med borbedringer og optimaliseringer! Og sist, men ikke minst, CPU'er som klarer å fore SLi oppsettet med data! :yes:
Edit: [H]ard|OCP har laget en SLi oppgraderings guide...
http://www.hardocp.com/article.html?art=Njk2LDE=
While the 6800 GT SLI and 6800 Ultra SL will likely get most of the glory today with performance that is unstoppable, the GeForce 6600 GT SLI is what really shines like a beacon in the night. For around $600 you can get a SLI gaming rig that will deliver better than 6800 GT gaming performance. Along with that, you have the option to upgrading to 6800 GTs or Ultras in the next year as prices start to slide down. I have already seen Unreal Engine 3 running flawlessly on lesser 6800-based mobile hardware so I feel very good about the longevity of 6800 series SLI. For the gaming or hardware enthusiast, this is certainly Must Have Hardware. Without a doubt, the GeForce 6600GT represents a hell of a SLI “starter set” that will keep most of us gaming very happily.
Edit2: Iallefall ASUS legger SLi bruen med hovedkortene sine, så da stemte ikke spekulasjonene som har gått om at du måtte kjøpe en SLi bru til noen hundre kroner ekstra! :thumbup:
Endret av [GDI]Raptor
Ja selv en FX-55 CPU er flaskehals for ett SLI oppsett. Det jeg har sett på CPU roadmaps, så skjer det ikke store ytelses økningen i 2005 heller. Kanskje nVidia og ATI må stoppe utviklingen av GPU'er en stund sånn at Intel og AMD kan komme med noe som er raskt nok :p
Hm, [H]ard|OCPs påstand om at to 6600GT yter bedre enn én 6800GT forundrer meg. Den mest interessante generaliseringen om SLI jeg har klart å komme over er jo det motsatte, og dette ser jo ut til å bekreftes av alle tester jeg har lest. Hos Firingsquad poengeter de riktignok at to 6600GT kort slår ett 6800GT-kort i Doom 3 i 1024x768-oppløsning uten AA og AF, men det er jo et unntak, og hvem er interessert i å stoppe der...
Anandtech er kanskje mest uttrykkelig her: " It doesn’t make too much sense to buy a pair of 6600GTs today however, as you’d be much better off getting a single 6800GT and upgrading to a second one down the road, which brings us to our next point, the upgrade value of SLI. "
Endret av bureaucrator
Raptor' date='24/11/2004 : 15:53'] FiringSquad tester også nVidia SLi
http://www.firingsquad.com/hardware/nvidia...sli/default.asp
:thumbup:
Dette er jo old news. Sto jo tester av sli for et par mnder siden. Og om man leser så er jo 2x6600 dårligere enn et 6800gt og dyrere. Da er jo vitsen borte med de kortene. Og i tillegg så er det jo slett ikke alle spill det gir noe enorm boost til.
Nei sli er dyrt og overprisa ytelse..er ikke mange normale folk som blåser 10000 på gfx. Og de som gjør det er folk som lever for 3dmark. x800xt eller 6800ultra holder da enda for de fleste. En kompis kjøpte i sin tid 2xvoodo2 sli. Var ikke lenge etter agp kortene kom og gav bedre ytelse til lavere pris.
Det er ikke old news, de testene av SLi som var for en måned siden var AnandTech var bare en liten preview. Nå er ASUS sine SLi hovedkort på vei ut i markedet... Og SLi kort er allerede ute.
SLi er en god mulighet til å få mere power hvis du trenger det.
En av grunnene til at SLi ikke fortsettet med AGP var at det kun var 1 AGP slot på hovedkortene.
"It doesn’t make too much sense to buy a pair of 6600GTs today however, as you’d be much better off getting a single 6800GT and upgrading to a second one down the road, which brings us to our next point, the upgrade value of SLI."
Nettopp. Det er slike situasjoner SLI er ment for (samt selvfølgelig for fanatikerne).
For det første er det ikke gammelt nytt, nei. For det andre; om du ikke klarer å tenke deg flere muligheter enn at folk kjøper 2x GT/Ultra så er det jo ikke håp for at du noensinne skal kunne tjene på å kjøpe SLI... det er jo på det rene. Oss andre kan jo selvfølgelig ta i bruk mulighetene SLI gir....
