Googolplex hvor mange nuller?
Izor
Siden det tydeligvis er FANTASTISK vanskelig å trykke på linken i nest øverste innlegg, poster jeg deler av artikkelen her:
A googolplex is the number , that is, 1 followed by a googol zeroes. The term googol was coined by the nephew of mathematician Edward Kasner. Googolplex was coined by Kasner to define an especially large number by extension from his nephew's idea. [1]
A googol is greater than the number of particles in the known universe, which has been variously estimated from 10^72 up to 10^87. Since this is less than the number of zeroes in a googolplex, it would not be possible to write down or store a googolplex in decimal notation, even if all the matter in the known universe were converted into paper and ink or disk drives.
Thinking of this another way, consider printing the digits of a googolplex in unreadable, 1-point font. Tex 1pt font is .3514598mm per digit, which means it would take about 3.5 * 10^96 meters to write in one point font. The known universe is estimated at 7.4 * 10^26 meters in diameter, which means the distance to write the digits would be about 4.7 * 10^69 times the diameter of the known universe.
Endret av G2Petter
Les på Wikipedia og bli klok!
Næmmen, ide!
For å svare på det første innlegget: 10 to the power of 100 zeroes betyr 10^100 nulltegn - vilket vil tilsi 1 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 nulltegn!
edit3: bah, teh speed of posters!
Endret av orcblood
@Jonas:
OK, trodde du mente det. Hvaslags output skal programmet gi deg, da?
En txt-fil.
Men uansett så er det nok ikke mulig .. har holdt på å regne i et par timer nå, og den er kansje 0,03% ferdig. Filen er 26,1 MB allerede :p
Edit: LOL!!!! Zip'a tok den bare 16,0 KB :wow:
Endret av Jonas
  • 4 år senere...
Hvor mange nuller består googolplex egentlig av? leste litt på internett å fant dette.
In print, a Googol also looks quite uninteresting. It is a 1 followed by 100 zeroes. It's boring. Now a Googolplex has a 1 followed by 10 to the power of 100 zeroes.
hva betyr dette? "10 the power of 100 zeroes"? :dontgetit:
En googol: 1 etterfulgt av 100 nuller.
En googolplex: 1 etterfulgt av 1 googol nuller.
En googolplex har flere nuller en det er partikler i universet, og hvis du skulle skrevet tallet på A4-ark hadde du trengt 600 000 000 000 universer for å få plass til alle arkene.
Det observerbare universet har plass til ~10^123bits med informasjon. Dette er kjent som "Hawking-Bekenstein bound". Det er grunnen til at man ikke kan skrive ut en googolplex med 1 fulgt av en googol med nuller innenfor det observerbare universet.
Jeg trengte maskinen, så jeg stoppet den. Starter nå, og ser litt på tv.
Edit: Har funnet ut at dette kommer til å ta mektig lang tid :p Bare prøv vedlegget.
Edit: Hvis programmet, en eller annen gang, har regnet ut tallet, vil det bli lagret på pc'en som en txt-fil. C:\Googolplex.txt
Eh. IKKE kjør programmer random folk på forum poster, med mindre du har kildekoden og kompilerer det selv.
@Jonas:
En txt-fil.
Vel, den zip-fila er nå sånn ca. en header + ascii-koden for et ett-tal + ascii-koden for "0", etterfulgt av "gjenta ørten ganger". Hvilket språk skriver du i? 26 MB på et par timer er TREIGT - 100 megabyte på et par sekunder (inkludert beregninger - som burde være ikke-eksisterende i dette tilfellet) er mer å forvente. Forøvrig: Hvaslags datatype bruker du for tellevariabelen i løkken din? :p
Sidan dei tråden og dei fleste innlegga er frå 2004 blir det vanskeleg å diskutere med dei som posta i tråden for fem år sidan. Dersom dette er noko dykk vil diskutere kan ein ny tråd åpnast, eventuelt bruke ein av nyare dato.
Tråden stenges. :)
Gjest
