Ny Brothers in Arms filmsnutt.
Det var en fin trailer, men den viser jo at AI'en er helt på trynet. Får for Gud's skyld håpe den er bedre i spillet enn hva denne traileren viser.
AI`en er jo det Gearbox skal ha arbeidet mest med på BiA.
hehe, ja, og så? Selv om de har jobbet mye med den kan det jo hende den er elendig. Jeg sier bare at hvis du ser på den traileren så ser du hvordan fiendene oppfører seg og hvordan den tanksen sprer kulene uten å treffe osv. Men det kan jo hende at det dem viser her ikke er representativt for det endelige produkt. Ikke vet jeg, men det skal bli spennende å sette seg ned med dette spillet ja ;)
Kansje fordi han som satt i tanken var en tysker :p
Det er vel MP på BiA ?
edit: Skriveleif :dribble:
Endret av SpinNdre
som dei fleste andre spel (stort sett bare med unntak av hl2) så er det ein mp del.
MULTIPLAYER
The multiplayer of Brothers in arms is totally different from all multiplay modes which we ever seen in other games. It is an unique combination between a first person shooter and a tactical game, where you as LEADER of three AI’s must kill the enemy soldiers in a strategic manner.
With Xbox live it is only possible to play with four human players in a server, with the result that you play’s with eight against eight including AI soldiers. For the pc must still be looked how many human multiplayers can play together in one server. This will probable become more than by the Xbox. For the Playstation version, which probable comes later, there is probable no multiplayer option.
The trategic side seems mayby boring, but if you play it, you see that it’s very exciting to make the correct strategic decisions without losing your men. Just like the real war..
Mode types
There are twelve different missions in the multiplayer of Brothers in arms, which seems that you are in a singleplayer map, because every team has a task. For example the allies must eliminate the AA gun of the germans, and the germans must defend that AA gun. A round takes no longer then ten minutes.
Map editor
There comes a map editor for Brothers in arms, so you can make your own maps, and it is possible that you play online in your own map.
Produktet er snart "endelig". Gearbox håper på å være ferdig med spillet før jul. Uansett kan det jo hende at snutten er laget slik for at det skal se "kulere" ut. Gearbox sin spesialitet skal som sagt være AI`en i BiA.
Jeg skulle likt å visst hvor du har den informasjonen om at de vil ha det ut før jul fra...
Annet enn at det kanskje vil medføre større salg da.
Spillet har ifølge tothegame release date den 25 februar i UK. Vi bør forholde oss til det.
Jess stemmer det der, men har ikkje spillutviklere sagt at AI i spillene deres i løpet av det siste året er så bra å blabla, ingen scriptede sekvenser på Fiender.De avgjør etter spilerens valg..(MOHPA noen) meeeen eg tviler ikkje pa at AI i dette spill vil svikte oss, om den gjør det vil eg aldri stole på en som sier at AI i deres spil er den beste noensinne eller skiller seg ut i fra andre spill..
EDIT: trailer var fantastisk :dribble:
Endret av Mala
